SD Card Library of Arduino not working in Proteus.
Hello!! Everyone.
I am trying to simulate the Arduino and its libraries in Labcenter Electronoics Proteus but its not working there.
MMC Command not support is the error i am getting, while the code is working properly on real Hardware.
I have to test something on proteus which i can't test practically right now, so i am asking for this.
If some has done this before successfully then please share his procedure with me.
I am using Proteus 8.1 please help.
You will find many question on this forum with simulator problems. There is no good simulator, they all are not very good. Perhaps they can simulate something like a blinking led, but as soon as special hardware is used, or something with timing problems, the simulators fail.
Yes that's the point, that Simulation doesn't support each and everything.
Previously i had tested the proteus memory card with mikroc compiler and that work for me as shown in this video.
I will try with latest library SdFat and report what happen, as it might be possible that SD library is old which might cause the problem.
Or i will make hardware and test on it, i have no other option.
Anyone got this SDcard problem resolved...
