SD Card locked into Read Only Mode after initilization using arduino ide and Seeeduino XIAO
after using arduino ide and seeeduino XIAO expansion board my proto program to log temp and humidity sensor data to micro sd card i notice the log file not being updated
i put micro sd card in sd card adapter and place in computer laptop windows 10
software indicate card is locked but not locked physically nothing will allow format or delete
somethng must have happened when program running but cannot use sd card anymore because it has 2 useless files onboard... any help would be apreciated
Is this an error/information message from a program on your Win10 system?
Can your Win10 system create a new file on the card?
I wonder if somehow the file on your SD card has somehow been marked as read only.
You should be able to use the SD card formatting utility mentioned in a sticky at the top of the storage section of the forum to reformat the card. Link below:
This should get you going again. However, I have had several SD cards that refuse to format on Win10 and I had to use a Linux system and run gparted to wipe all the partitions.
If memory serves, each time it happened to me, Windows couldn't do anything with the card. I wish I could recall the exact message. Standard format didn't work, etc. I have an old netbook with Puppy Linux on it and I used the gparted tool on that to remove all partitions from the SD card. I can't recall if I used gparted to put a FAT filesystem back on the SD card, or put the card back in a Windows PC and ran the SD formatting utility. It may be the latter as that's the suggestion in the sticky in the storage section.
Just in case it might help - do you know there is a little tab/slider on the card adapter that locks the card in a read-only mode? It is very easy to nudge that out of the read/write position.
i have used google to download several disk partition utilities which have not been effective
usually scam free programs which i quickly uninstalled
somehow the card has a flag set that tells the os it is write protected and no amount of brute force will change its mind... i used windows cmd diskpart to no effect. have not tried regedit as it is also locked on arduino which does not have a regestry.... some say card is defective...
it may be possable that card is defective and refusing to respond but i am able to open the single file it contains
i assume the arduino was in the process of writing to the card when power was interupted or program compiled and pushed which caused... i have added a push button to abort code execution in the future before push or powerdown gotta go to another machine and get a usb to sd adapter to try formatting via linux
