Hi All,
I have been using this code to log info to an SD card. However whenever i get the results back.
0.00,0.00,2.78
Sucessful Log
3VA1: 0 3.3 Volt =0.00
5VAO: 0 5 Volt =0.00
LDRA2: 464.00 LDR Volt =2.78
0.00,0.00,2.78
Sucessful Log
The Successful log statement is supposed to let me know when the SD card was successful since it comes after the close file statement. However when i look in the SD card on the computer, it never actually logs it on the SD card. Sometimes i will get error logging text file until i change the name of the file. Can someone please help me understand why i have nothing on my SD card even thought it says log sucessfull?
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
Sd2Card card;
SdVolume volume;
SdFile root;
Serial.println("initializing SD Card...");
if (!SD.begin(chipSelect)){
Serial.println("Card Failed, or not Present");
return;
pinMode (8,OUTPUT);
int Three = analogRead(A0);
Serial.print("3VA1: ");
Serial.print(Three);
float Three1 = Three*(3.3/683);
Serial.print(" ");
Serial.print("3.3 Volt =");
Serial.print(Three1);
int Five = analogRead(A1);
Serial.println("");
Serial.print("5VAO: ");
Serial.print(Five);
float Five1= Five* (5.0/1023.0);
Serial.print(" ");
Serial.print(" 5 Volt =");
Serial.println(Five1);
float LDR = analogRead(A2);
Serial.print("");
Serial.print("LDRA2: ");
Serial.print(LDR);
float LDR1= LDR* (5.0/835.0);
Serial.print(" ");
Serial.print(" LDR Volt =");
Serial.println(LDR1);
Serial.println("");
if (LDR1 > 4.0){
digitalWrite(8,LOW);
else{
digitalWrite(8,HIGH);
String dataString = String(Three1) + "," + String(Five1) + "," + String(LDR1);
Serial.println(dataString);
File Voltage = SD.open("vol.txt", FILE_WRITE);
if (Voltage){
Voltage.println(dataString);
Voltage.close();
Serial.println("Sucessful Log");
else {
Serial.println("error opening voltage.txt");
