hi i am a newbie in arduino i just want to know/ have an advise about our project . We have x3 water level sensor and i am having trouble storing data in micro sd card and functioning the sensors. here is my code
#include <SD.h>
#include <SPI.h>
#include <DS3231.h>
DS3231 rtc(SDA, SCL);
File myFile;
String fileName = "water.csv ";
int pinCS = 53; // //the input pin (for a SD card)
int waterval1 = 0;
int waterval2 = 0;
int waterval3 = 0;
int sensor1 = A0; //the input pin (for sensor1)
int sensor2 = A1; //the input pin (for sensor2)
int sensor3 = A2; //the input pin (for sensor3)
int yellow = 3; //the input pin (for LED yellow)
int red = 4; //the input pin (for LED red)
int green = 2; //the input pin (for LED green)
int alarm = 7; //the input pin (for a buzzer)
int button = 5; //the input pin (for a pushbutton)
pinMode(pinCS,OUTPUT);
pinMode(button,INPUT); // declare pushbutton as input
pinMode (red,OUTPUT); // LED red
pinMode (yellow,OUTPUT); // LED yellow
pinMode (green,OUTPUT); // LED green
pinMode(alarm,OUTPUT); // Buzzer
digitalWrite(alarm, LOW);
digitalWrite(red, LOW);
digitalWrite(yellow, LOW);
digitalWrite(green, LOW);
// SD Card Initialization
if (SD.begin())
Serial.println("SD card is ready to use.");
} else
Serial.println("SD card initialization failed");
return;
rtc.begin();
waterval1= analogRead(A0); //read water level value for sensor 1
waterval2= analogRead(A1); //read water level value for sensor 2
waterval3= analogRead(A2); //read water level value for sensor 3
Serial.print(waterval1);
Serial.print(waterval2);
Serial.print(waterval3);
button =digitalRead(5); //button
digitalWrite(alarm, LOW); //buzzer
//For Sensor 1
if ((waterval1 > 0) && (waterval1 <= 400))
digitalWrite (red,LOW);
digitalWrite(yellow,LOW);
digitalWrite(green,LOW);
digitalWrite(alarm,LOW);
else if (waterval1 > 400) {
Serial.println("Water Level 1 is 3.2cm");
digitalWrite(green,HIGH);
digitalWrite(alarm,HIGH);
tone(alarm, 10000, 300);
delay(3300);
// Send Day-of-Week
Serial.print(rtc.getDOWStr());
Serial.print(" ");
// Send date
Serial.print(rtc.getDateStr());
Serial.print(" -- ");
// Send time
Serial.println(rtc.getTimeStr());
Serial.print(" ");
myFile = SD.open("test.txt", FILE_WRITE);
if (myFile) {
myFile.print(rtc.getTimeStr());
myFile.print(",");
myFile.print(rtc.getDOWStr());
myFile.print(" ");
myFile.print(rtc.getDateStr());
myFile.print(" -- ");
myFile.println(waterval1);
myFile.close(); // close the file
// if the file didn't open, print an error:
else {
Serial.println("error opening test.txt");
delay(5000);
//For Sensor 2
if ((waterval2 < 0) && (waterval2 <= 400)) {
Serial.println("Water Level 2 is 6.4cm");
else if (waterval2 > 400)
digitalWrite(yellow,HIGH);
tone(alarm, 10000, 500);
delay(2500);
// Send Day-of-Week
Serial.print(" ");
// Send date
// Send time
Serial.print(" ");
if (myFile) {
myFile.print(",");
myFile.print(" ");
myFile.println(waterval2);
else {
delay(5000);
//For Sensor 3
if ((waterval3 < 0) && (waterval3 <= 400))
Serial.println("Water Level 3 is 9.4cm");
else if (waterval3 > 400) {
digitalWrite (red,HIGH);
delay(1300);
// Send Day-of-Week
Serial.print(" ");
// Send date
// Send time
Serial.print(" ");
if (myFile) {
myFile.print(",");
myFile.print(" ");
myFile.println(waterval3);
else {
delay(5000);
//For Button
if (button ==1)
digitalWrite(red, HIGH);
delay(3300);
tone(alarm,0,0);
