SD Card Module and Speaker + Arduino MEGA 2560
Greetings to everyone, I am developing a project - a drum machine based on the Arduino MEGA 2560 and I have some difficulties.
The principle of operation of the device is that the Arduino Mega 2560 reads the signal from the touch buttons and plays sounds using the speaker stored on the SD card.
The key problem is that the speaker (universal speaker on the 4th) reproduces different generated sounds, the SD card is initialized, but for some unknown reason they do not interact with each other, although in Serial Monitor all processes proceed smoothly and there are no errors and plugs.
Files are stored on the memory card in wav resolution, 8 bits, 8khz, mono (I tried both 16 bits and 16 khz, removed file numbering). At the moment, the file is recorded as "sound" and it is stored on a formatted 2gb memory card.
P.S.this is my first Arduino-based project, so please treat my question with understanding, thank you in advance!
#include <Wire.h>
#include <SD.h>
#include <SPI.h>
#include <TMRpcm.h>
#define SD_ChipSelectPin 53
#define SpeakerPin 3
#define ENCODER_S1 7
#define ENCODER_S2 8
#define ENCODER_KEY 6
TMRpcm audio;
LiquidCrystal_I2C lcd(0x27, 16, 2);
const int sensorPins[9] = {2, 3, 4, 5, 9, 10, 11, 12, 13};
int pattern = 0;
int bpm = 120;
int volume = 5;
bool adjustVolume = false;
volatile long lastEncoderPosition = 0;
void listFiles() {
  File root = SD.open("/");
  while (true) {
    File entry = root.openNextFile();
    if (!entry) {
      // no more files
    Serial.print("File: ");
    Serial.println(entry.name());
    entry.close();
void playSound(int soundNum) {
  String soundFile = "sound" + String(soundNum) + ".wav";
  Serial.print("Attempting to play sound: ");
  Serial.println(soundFile);
  if (SD.exists(soundFile)) {
    Serial.println("File exists, playing...");
    audio.play(soundFile.c_str());  // Преобразование String в const char*
    lcd.setCursor(0, 1);
    lcd.print("File Missing ");
    Serial.println("File Missing");
  Serial.begin(9600);  // Для отладки
  lcd.begin(16, 2);  // Укажите количество столбцов и строк
  lcd.backlight();
  lcd.print("DIY Drum Machine");
  for (int i = 0; i < 9; i++) {
    pinMode(sensorPins[i], INPUT);
  pinMode(SpeakerPin, OUTPUT);
  audio.speakerPin = SpeakerPin;
  lcd.print("Initializing SD");
  Serial.println("Initializing SD card...");
  // Попытка инициализации SD карты с несколькими попытками
  bool sdInitSuccess = false;
  for (int attempt = 0; attempt < 5; attempt++) {
    if (SD.begin(SD_ChipSelectPin)) {
      sdInitSuccess = true;
    delay(500); // Задержка перед повторной попыткой
  if (!sdInitSuccess) {
    lcd.print("SD Init Fail  ");
    Serial.println("SD Initialization Failed");
    return;
  lcd.print("SD Init Success");
  Serial.println("SD Initialization Success");
  // Дополнительные настройки для TMRpcm
  audio.setVolume(volume);  // Установить начальный уровень громкости
  audio.quality(1);    // Повышенное качество звука
  // Список файлов на SD карте для отладки
  listFiles();
  // Настройка энкодера
  pinMode(ENCODER_S1, INPUT);
  pinMode(ENCODER_S2, INPUT);
  pinMode(ENCODER_KEY, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(ENCODER_S1), updateEncoder, CHANGE);
  attachInterrupt(digitalPinToInterrupt(ENCODER_S2), updateEncoder, CHANGE);
  // Обработка сенсорных кнопок
    if (digitalRead(sensorPins[i]) == HIGH) {
      Serial.print("Sensor pin ");
      Serial.print(sensorPins[i]);
      Serial.println(" activated.");
      playSound(i + 1);
      lcd.print("Sound: ");
      lcd.print(i + 1);
      delay(1000); // Задержка для предотвращения слишком частого считывания
  // Обработка нажатия кнопки энкодера
  if (digitalRead(ENCODER_KEY) == LOW) {
    adjustVolume = !adjustVolume; // Переключение между режимами регулировки громкости и BPM
    if (adjustVolume) {
      lcd.setCursor(0, 0);
      lcd.print("Volume: ");
      lcd.print(volume);
      lcd.print("   "); // Очищаем остаточные символы
      lcd.print("BPM: ");
      lcd.print(bpm);
    delay(300); // Задержка для устранения дребезга кнопки
  // Обновление значения BPM или громкости в зависимости от текущего режима
  if (adjustVolume) {
    int newBpm = map(lastEncoderPosition, -1023, 1023, 60, 180);
    if (newBpm != bpm) {
      bpm = newBpm;
      lcd.print("BPM: ");
      lcd.print(bpm);
      lcd.print("   "); // Убираем возможные остаточные символы
      Serial.print("Updated BPM: ");
      Serial.println(bpm);
  delay(100); // Задержка для улучшения читаемости
void updateEncoder() {
  int s1State = digitalRead(ENCODER_S1);
  int s2State = digitalRead(ENCODER_S2);
  if (s1State != s2State) {
    lastEncoderPosition++;
    if (adjustVolume && volume < 7) {
      volume++;
      Serial.print("Volume increased to: ");
      Serial.println(volume);
      lcd.print(volume);
    lastEncoderPosition--;
    if (adjustVolume && volume > 0) {
      volume--;
      Serial.print("Volume decreased to: ");
      lcd.print(volume);
  if (!adjustVolume) {
    lcd.print("BPM: ");
    lcd.print(bpm);
The library shows the speaker pin on a Mega should be 5,6,11 or 46. Don't know why.
Thanks for noticing this, my friend, my speaker is connected to 3 pins.
You cannot freely choose which pin you want. According to the library documentation, you need a pin that has PWM and is controlled by a 16-bit timer.
5,6,11 or 46 on Mega, 9 on Uno, Nano
Single timer operation: TIMER1 (Uno,Mega) or TIMER3,4 or 5 (Mega)
@flashko: Thanks! I knew there must be a reason. I didn't know it.
Everything worked for me, thanks guys, you are insanely cool!
Glad to help. Have fun with Arduino.
That was a good learning experience for me I am trying to use a 4 ohm 3 w speaker for my project which is basically making my animatronic talk but I don't have the patience to order an amp and I have had to act out my animatronics talking like a puppeteer and have audio coming form a cheap Bluetooth speaker that I took apart and put it inside the animatronics mouth. Is there anyway that I can use the 3.5 aux cable cut open that cable and extract that positive and negative and attach it to my Arduino and use the OG speakers a amp? It could probably work for you too.
