Hi, I'm trying to figure out why my sd card sometimes work. but then at some point just stops working and keeps throwing:
SD card initialization failed!
begin() failed
Do not reformat the SD.
SdError: 0X17,0XFF
the hardware is the following:
The setup code I'm using is the following:
// Setup handlers
CardHandler cardHandler = CardHandler();
while (!Serial)
; // wait for serial port to connect. Needed for native USB port only
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi");
// Print the local IP address
Serial.print("Local IP address: ");
// print the gateway IP address
Serial.print("Gateway IP address: ");
Serial.println(WiFi.gatewayIP());
// print the subnet mask
Serial.print("Subnet mask: ");
Serial.println(WiFi.subnetMask());
// disable bluetooth
esp_bt_controller_disable();
// Add some delay so we can see the serial output
try
// initialize card reader
cardHandler.init();
Serial.println("Card reader initialized");
catch (const std::exception &e)
Serial.println(e.what());
while (true)
the cardreader looks like this:
#include "FS.h"
#include "SPI.h"
#include <SdFat.h>
#include "Wire.h"
#include "CardReader.h"
// Try to select the best SD card configuration.
#if HAS_SDIO_CLASS
#define SD_CONFIG SdioConfig(FIFO_SDIO)
#elif ENABLE_DEDICATED_SPI
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, DEDICATED_SPI, SPI_CLOCK)
#else // HAS_SDIO_CLASS
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, SHARED_SPI, SPI_CLOCK)
#endif // HAS_SDIO_CLASS
CardHandler::CardHandler()
void CardHandler::init()
try
Serial.println("CardHandler Setup");
if (!_sd.begin(SD_CONFIG))
Serial.println("SD card initialization failed!");
_sd.initErrorHalt(&Serial);
return;
uint32_t size = _sd.card()->sectorCount();
if (size == 0)
Serial.println("Can't determine the card size.\n");
return;
Serial.print("Card size: ");
Serial.print(size / 1024);
Serial.println(" MB");
Serial.println("CardHandler Setup Failed");
Serial.print("Exception: ");
catch (...)
file_t CardHandler::getFile(const char *filename, uint8_t oflag)
#if SD_FAT_TYPE == 0
File file;
#elif SD_FAT_TYPE == 1
File32 file;
#elif SD_FAT_TYPE == 2
ExFile file;
#elif SD_FAT_TYPE == 3
FsFile file;
#else // SD_FAT_TYPE
#error Invalid SD_FAT_TYPE
#endif // SD_FAT_TYPE
// Open or create
if (!file.open(filename, oflag))
_sd.errorHalt(&Serial, "Failed to open file for writing");
return file_t();
// Return
return file;
void CardHandler::removeFile(const char *filename)
if (!_sd.remove(filename))
_sd.errorHalt(&Serial, "Failed to remove file");
void CardHandler::closeFile(file_t file)
file.close();
and it's header file
#ifndef CARD_READER_H
#define CARD_READER_H
#include <FS.h>
#include <SD.h>
#include <SdFat.h>
#include <driver/i2s.h>
#include <Arduino.h>
#define SD_FAT_TYPE 2
// SDCARD_SS_PIN is defined for the built-in SD on some boards.
#ifndef SDCARD_SS_PIN
const uint8_t SD_CS_PIN = GPIO_NUM_5;
#else // SDCARD_SS_PIN
// Assume built-in SD is used.
const uint8_t SD_CS_PIN = SDCARD_SS_PIN;
SDCARD_SS_PIN
#endif //
// Try max SPI clock for an SD. Reduce SPI_CLOCK if errors occur.
#define SPI_CLOCK SD_SCK_MHZ(50)
typedef File file_t;
typedef SdFat sd_t;
typedef SdFat32 sd_t;
typedef File32 file_t;
typedef SdExFat sd_t;
typedef ExFile file_t;
typedef SdFs sd_t;
typedef FsFile file_t;
class CardHandler
public:
CardHandler();
void init();
file_t getFile(const char *filename, uint8_t oflag = O_APPEND | O_WRITE | O_CREAT);
void removeFile(const char *filename);
void closeFile(file_t file);
private:
sd_t _sd;
bool _connected;
#endif // CARD_READER_H
I've been trying a lot of things (changing baudrate, the clockspeed, ...). but it's just random when it starts failing and when it works.
Sometimes reformatting does the trick, sometimes this doesn't do anything
I'm scratching in my hair trying to find this out
