SD card not working anymore when removing card
Hello friends.
What i am using: ESP32, Nextion display, SD card reader
I think the threadtitel says it all. I am using a SD card to store some measured data. Everything works fine. When i upload my scetch everything i want to log and store into my sd card works.
But when i unplugg the sd card and plug it back in, the sd card isnt working anymore.
What i have found out so far: From my research here in this forum assume that this part of code SD.begin(PIN);, is the key to my solution. So it will initalize the Sd card in my code once. Now when i unplugg and replug my Sd card back into my ESP, this initialization and connection is lost.
I also found a thread with the same problem. He solved the problem, with changing some stuff in SD.h and SD.cpp file. Since this is not my first choice, i want to ask ou guys if anyone found another solution. Plugging/unplugging SD card [solved] - Programming Questions - Arduino Forum
the code (part of it)
  RTC_DS3231 rtc2;
  DateTime now3 = rtc2.now();
  nexInit();
  Serial2.begin(19200, SERIAL_8N1, RXD2, TXD2);
  EEPROM.begin(64);        //Nach derzeitgen Wissen definiert man so die Größe des EEPROMs. Man "reserviert" sich quasi Speicher. Müsste bis 255 gehen
  ph.begin();        //holt bzw. initialisiert sich die Daten der gespeicherten Messwerte für 7er und 4er Lösung aus EEPROM
  //Serial COM
  Wire.begin();
   // while the serial stream is not open, do nothing:
  while (!Serial) ;
  ****************SD Initializing process**********
  SD.begin(5);
  Serial.print("Initializing SD card...");
  if (!SD.begin(5))
    Serial.println("initialization failed!");
    //return;
  uint8_t cardType = SD.cardType();
  if(cardType == CARD_NONE) {
    Serial.println("No SD card attached");
    //return;
This is the part of the code, where i store the data on my Sd card. I also tried to execute the initialisation again in my function. Without sucsess.
void logSDCard_Alarms(String t_message)
  String fileName = "/Errormessages.txt";
  char charFileName[fileName.length() + 1];
  fileName.toCharArray(charFileName, sizeof(charFileName));
  String dataMessage;
  SD.begin(5);    //test
  File dataFile = SD.open(charFileName);
    if(!dataFile)
      Serial.println("File doens't exist");
      Serial.println("Creating file...");
      writeFile(SD, charFileName, "Timestamp,Message \r\n");
  dataMessage =  t_message + "\r\n";
  Serial.print("Save data: ");
  Serial.println(dataMessage);
  appendFile(SD, charFileName, dataMessage.c_str());
  dataFile.close();
Any ideas?
Thank you
So i think that the problem is, that you can only use SD.begin(PIN) once. Has anyone encountered the same problem?
thank you
