SD Card not working, but others do
I have these cheap 128mb SD cards from AliExpress. I have a ESP8266 board with Micro SD card slot I designed and had fabricated. I am having trouble getting the SD card to initialize.
I have tried another card, and it works fine. So I know the electrical circuit is working correctly. It's all working on 3.3v. There's no pullup/down resistors. And there is a 100nf bypass cap on the 3.3v.
I have tried this 128mb card in a Windows and mac computer, and a digital microscope. There's no problem with them. and they are able to write/read.
The only odd thing I'm seeing that could help diagnose the problem is that the test.txt file I put on the card in windows, gets deleted when put into my project. the other files on the card don't get touched and remain on the card.
I found another post talking about changing the speed of the SPI, tried at 15mhz and 4mhz, and it didn't solve the problem.
Any thoughts?
I would not buy resistors from Aliexpress and expect them to be in spec, never mind an SD card.
Try deleting and making the main partition again. In Windows I use the free version of the Aomei Partition Manager. I have recovered some "bad" flash drives.
I have purchased dozens of modules from Ali Express, mostly ESP variations, and never a problem. (I don't recall ever buying memory devices). However, Ali Express is simply a storefront for thousands of vendors. Ali Express does not stock anything. If you have a bad experience, it's with the seller. Not Ali Express.
I tried the Aomei software. Deleted the partition, and recreated a new one. Still no luck. I tried a FAT32, and creation succeeded. Was able to write my test.txt in windows. Then tried with the circuit I made, and it didn't initialize. Tried connecting back to windows, and now Windows can't even see the drive.
I tried another card, partitioned to FAT16 (FAT) and it has the same problem as before; Windows can see it, but my circuit can't initialize the card, but the file is deleted! So strange.
And ya, mostly good experience with AliExpress here. Any issues I've had I get refunds. Maybe it's time to try with this, although it may be too late.
