SD Card not working with logging shield
Hi
I am midway through a project where I am required to log data from an accelerometer to an SD card (I'm of mechanical discipline so go easy on me please!).
I have managed to get a serial output from the accelerometer so that is not an issue.
The data logging shield I am using is this one (Rev B) which came recommended by colleagues and online. Using a 16GB class 10 microSDHC (w/ adapter), formatted using the SD formatter utility to FAT32. The chip select pin has been set to 10 as recommended in the adafruit docs, though I have tried 4 and 8 aswell just in case.
Initial tests have not gone well. Using the CardInfo sketch in the SD library I get the following output:
Initializing SD card...initialization failed. Things to check:
* is a card inserted?
* is your wiring correct?
* did you change the chipSelect pin to match your shield or module?
From searching on this forum I found recommendations to use the SdInfo sketch from the SdFat library available online, for a more descriptive error. This produces the following output:
SdFat version: 20160719
Assuming the SD is the only SPI device.
Edit DISABLE_CHIP_SELECT to disable another device.
Assuming the SD chip select pin is: 10
Edit SD_CHIP_SELECT to change the SD chip select pin.
type any character to start
cardBegin failed
SD errorCode: 0X1
SD errorData: 0X0
And the QuickStart sketch in the same library:
SPI pins:
MISO: 12
MOSI: 11
SCK:  13
SS:   10
Be sure to edit DISABLE_CHIP_SELECT if you have
a second SPI device.  For example, with the Ethernet
shield, DISABLE_CHIP_SELECT should be set to 10
to disable the Ethernet controller.
SD chip select is the key hardware option.
Common values are:
Arduino Ethernet shield, pin 4
Sparkfun SD shield, pin 8
Adafruit SD shields and modules, pin 10
Enter the chip select pin number: 10
SD initialization failed.
Do not reformat the card!
Is the card correctly inserted?
Is chipSelect set to the correct value?
Does another SPI device need to be disabled?
Is there a wiring/soldering problem?
errorCode: 0x1, errorData: 0x0
Restarting
From reading other posts it is apparent that this does not necessarily indicate a dud SD card, but none of the posted solutions have worked for me. Are there any glaring errors or oversights that I am missing? Any assistance is much appreciated.
