Hi, having got over my inital problems with the Wemos® Mega +WiFi R3 Module ATmega2560+ESP8266 I am now moving onto the next steps which is adding an SD Card to the board.
The SD Card module I got where these from Banggood
From looking at the details it tells me it has a 5v-3.3v regulator built in, so I should not need to level shift (I presume so though I am a noob with memory issues so I could be wrong)
I have added the sd card module and connected the pins to…
- MISO - 50
- SCK - 52
- MOSI - 51
- CS - 53
- Vcc to Mega 5v
- Gnd to Mega Gnd
I then uploaded a simple script to the Mega but I just can not get the SD to initialised. The SD Card I have tried are all Fat32 formatted and in various sizes 2Gb, 4Gb 32Gb
The script I used was
#include <SPI.h>
#include <SD.h>
int CS_PIN = 53;
File file;
Serial.begin(57600);
initializeSD();
createFile("test.txt");
writeToFile("This is sample text!");
closeFile();
openFile("prefs.txt");
Serial.println(readLine());
closeFile();
void initializeSD()
Serial.println("Initializing SD card...");
pinMode(CS_PIN, OUTPUT);
if (SD.begin())
Serial.println("SD card is ready to use.");
} else
Serial.println("SD card initialization failed");
return;
int createFile(char filename[])
file = SD.open(filename, FILE_WRITE);
if (file)
Serial.println("File created successfully.");
return 1;
} else
Serial.println("Error while creating file.");
return 0;
int writeToFile(char text[])
if (file)
file.println(text);
Serial.println("Writing to file: ");
Serial.println(text);
return 1;
} else
Serial.println("Couldn't write to file");
return 0;
void closeFile()
if (file)
file.close();
Serial.println("File closed");
int openFile(char filename[])
file = SD.open(filename);
if (file)
Serial.println("File opened with success!");
return 1;
} else
Serial.println("Error opening file...");
return 0;
String readLine()
String received = "";
char ch;
while (file.available())
ch = file.read();
if (ch == '\n')
return String(received);
received += ch;
return "";
I then tried using the Mega 3.3v instead of the 5v and it still does not initialised.
I tried using a different pin for the CS but still does not get initialised.
The thing that is bugging me is that if I use my Uno (using the pins of the uno 10, 11, 12, 13) then the SD can be initialised and be write/read fine.
I have read many posts and tried various other things but to no avail.
any help or opinion would be most greatfull.
