SD Card on Ethernet Shield on MEGA not working
I bought a cheap Ethernet Shield to use the SD card slot for data storage. I have read (20 times) everything I can find and spent many happy hours trying to get it to work. In the example programs I just get “Initializing SD card…initialization failed!”.
I have tried the different SD libraries (Arduino and Adafruit (Older Datalogger Shield Leonardo & Mega Library | Adafruit Data Logger Shield | Adafruit Learning System). I have the shield plugged on top of the MEGA. Is there any simple (and complete) instructions anywhere to get my SD working?
My code:
  SD card basic file example
 This example shows how to create and destroy an SD card file
 The circuit:
 * SD card attached to SPI bus as follows:
 ** UNO:  MOSI - pin 11, MISO - pin 12, CLK - pin 13, CS - pin 4 (CS pin can be changed)
  and pin #10 (SS) must be an output
 ** Mega:  MOSI - pin 51, MISO - pin 50, CLK - pin 52, CS - pin 4 (CS pin can be changed)
  and pin #52 (SS) must be an output
 ** Leonardo: Connect to hardware SPI via the ICSP header
 created   Nov 2010 by David A. Mellis
 modified 9 Apr 2012 by Tom Igoe
 modified 13 June 2012 by Limor Fried
 This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File root;
// change this to match your SD shield or module;
//     Arduino Ethernet shield: pin 4
//     Adafruit SD shields and modules: pin 10
//     Sparkfun SD shield: pin 8
const int chipSelect = 4;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on Arduino Uno boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
//  pinMode(SS, OUTPUT);
  pinMode(53, OUTPUT);
//  if (!SD.begin(chipSelect)) {
  if (!SD.begin(10,11,12,13)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  root = SD.open("/");
  printDirectory(root, 0);
  Serial.println("done!");
  // nothing happens after setup finishes.
void printDirectory(File dir, int numTabs) {
  // Begin at the start of the directory
  dir.rewindDirectory();
  while(true) {
     File entry =  dir.openNextFile();
     if (! entry) {
       // no more files
       //Serial.println("**nomorefiles**");
     for (uint8_t i=0; i<numTabs; i++) {
       Serial.print('\t');   // we'll have a nice indentation
     // Print the 8.3 name
     Serial.print(entry.name());
     // Recurse for directories, otherwise print the file size
     if (entry.isDirectory()) {
       Serial.println("/");
       printDirectory(entry, numTabs+1);
       // files have sizes, directories do not
       Serial.print("\t\t");
       Serial.println(entry.size(), DEC);
     entry.close();
I even tried jumping pins 11,12,13 on the Ethernet shield to pins 51,50,52 (I also tried 50,51,52) respectably on the MEGA board. Nothing seems to work. Perhaps I have a bad shield? Thanks for any (un-wise-ass) help.
Got it working. For others having the same problem:
Don’t use any jumpers between pins on the boards.
Use the Arduino.CC version of SD.h
Code that works for me:
  SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module.
    Pin 4 used here for consistency with other Arduino examples
created  28 Mar 2011
by Limor Fried
modified 16 Mar 2011
by Tom Igoe
// include the SD library:
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
  Serial.print("\nInitializing SD card...");
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  pinMode(53, OUTPUT);     // change this to 53 on a mega
  pinMode(10,OUTPUT); // pin 10 must be left as an OUTPUT so it can be set HIGH
  digitalWrite(10,HIGH); // pin 10 needs to be put HIGH to explicitly deselect the WiFi HDG104 chip[code]
  digitalWrite(4,LOW);
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card is inserted?");
    Serial.println("* Is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    return;
   Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("\nCard type: ");
  switch(card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    return;
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("\nVolume type is FAT");
  Serial.println(volume.fatType(), DEC);
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize *= 512;                            // SD card blocks are always 512 bytes
  Serial.print("Volume size (bytes): ");
  Serial.println(volumesize);
  Serial.print("Volume size (Kbytes): ");
  volumesize /= 1024;
  Serial.print("Volume size (Mbytes): ");
  volumesize /= 1024;
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
[/code]
I still have a problem. The above code says the SD is present but it will not initalize with this code and I still get the “initialization failed!”.
  SD card test
The circuit:
created  28 Mar 2011
by Limor Fried
by Tom Igoe
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
    return;
  if (!SD.begin(4)) {
    default:
    return;
  volumesize /= 1024;
  volumesize /= 1024;
void loop(void) {
I do not say that I found a solution but I had the same issue as you and I'll tell you what I've done. As you I read and tried almost all suggested solutions from this forum without any progress to make my sd card projects working for me when it seems so easy for the others. I hope a more experienced member could explain to me why my temporary fix worked and how I can do it better because it's still a not perfect solution. My feeling is it's not a safe procedure but here we go: Once the code is uploaded and the Arduino ready, I insert the card and then I press the reset button. If the code end and I press the reset button again it won't work so each time I need to remove the card, re-insert the card and press the reset button. I have no clue why but it works for me and each time I'm afraid to damage the card or the module...
Sorry I can only compound this problem. I find the Arduino software 'flakey'. I have the oldest version I could find V1.0.6, and V1.6.5. I am using a MAC running the latest OSX 10.11.
I have quite an ambitious project in mind but I thought I would start on something simple. All I want to do is use a shield with a SD card and a RTC and write two time-stamped analogue values to the card. I am using the deek-robot Data Logging shield V1.0.
Although the 'card info' program works, I cannot initialise the card, so writing to it is not an option. Running different versions of the Arduino software give different inconsistent results. The serial port (serial monitor) is also is problematical, closing down one version of Arduino appears to leave this port open so opening another version fails with a warning the port is still open. I would think this should be easy, I am not new to programming or building electronic projects.
Does anyone know of a reliable combination / program to do this?
Many thanks, Andy
Andy207: The serial port (serial monitor) is also is problematical, closing down one version of Arduino appears to leave this port open so opening another version fails with a warning the port is still open. I would think this should be easy, I am not new to programming or building electronic projects.
When it happen to me, I close the serial monitor window and I try to upload the sketch again. If it still doesn't work, I disconnect the USB cable from my computer for 5-10 seconds (Make sure all the serial monitor windows are closed) I connect the USB cable to my computer and then It's working for almost 99% of the time.
I hope it'll be the same for you...
