SD Card Opening Failure
Hi. I'm using the Adafruit Datalogging Shield with an Arduino Uno and an Adafruit 8GB SD/MicroSD card.
The SD card has been formatted using the official formatter from: https://www.sdcard.org/downloads/formatter_4/eula_mac/index.html
And the SD card reader I'm using is the port on my MacBook (I've read that this could be the problem).
I'm following Jeremy Blum's tutorial in Chapter 13 of Exploring Arduino and I'm using the following code in order to test that my SD card is working properly:
#include <SD.h>
//Set by default for the SD card library
//MOSI = pin 11
//MISO = pin 12
//SCLK = pin 13
//We always need to set the CS Pin
const int CS_PIN=10;
//We set this high to provide power
const int POW_PIN=8;
  Serial.println("Initializing Card");
//CS pin is an output
  pinMode(CS_PIN, OUTPUT);
//Card will draw power from pin 8 so set it high
  pinMode(POW_PIN, OUTPUT);
  digitalWrite(POW_PIN, HIGH);
  if(!SD.begin(CS_PIN))
    Serial.println("Card Failure");
    return;
  Serial.println("Card Ready");
  long timeStamp = millis();
  String dataString="Hello There!";
  File dataFile = SD.open("log.csv", FILE_WRITE);
  if(dataFile)
    dataFile.print(timeStamp);
    dataFile.print(",");
    dataFile.println(dataString);
    dataFile.close();
    Serial.print(timeStamp);
    Serial.print(",");
    Serial.println(dataString);
    Serial.println("Couldn't open log file");
  delay(5000);
I keep getting "Card Failure". I've also tried the example code, CardInfo, from the SD library to no avail.
Any ideas why the card isn't opening?
I have executed your codes unchanged on my SD Card; the codes and the SD are working!
Please check wiring between SD Card and UNO!
I thought I didn't need to hook up my SPI bus from the Arduino to the datalogger shield but because I have the newer version of the shield, Rev B, I had to. Now it works!
Moral of the story: always read all the instructions for the piece of equipment you're working with!
