I've been trying to use my adafruit micro sd breakout board with my M0 feather rfm9x lora, but there has been problems with getting the sd module to work. I'm using the example code for the SD card library, but with the cs pin for the sd card as d5, yet the sd card fails to initialize, despite it being able to initialize on my arduino nano. Code posted below.
SD card basic file example
This example shows how to create and destroy an SD card file
The circuit:
SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(5)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
if (SD.exists("example.txt")) {
Serial.println("example.txt exists.");
Serial.println("example.txt doesn't exist.");
// open a new file and immediately close it:
Serial.println("Creating example.txt...");
myFile = SD.open("example.txt", FILE_WRITE);
myFile.close();
// Check to see if the file exists:
// delete the file:
Serial.println("Removing example.txt...");
SD.remove("example.txt");
// nothing happens after setup finishes.
