SD card (read/write) by SD card socket on 3.2" TFT LCD
I use: Arduino Mega 2560 TFT LCD Mega Shield V2.2 3.2" TFT LCD 320x240with SD card socket
I want to read/write "file.txt" from SD card (SD card on card socket of 3.2" TFT LCD ) I saw some topic and forum, but i not found the way to do it, help me :(
You need to check the relevant data sheets, and be more forthcoming on your code and equipment.
My 400x240 has the SD on the shield, and I had to bridge a pair of solder pads in order to use it. I understand yours is on the display but you may have to do a similar trick somewhere, most likely on the shield. I also had to change the chip select from the usual 4 to 53. This is in addition to the usual command
pinMode(53, OUTPUT);
required on the Mega. I believe both commands relevant to pin53 are required. This applies to the standard SD CardInfo example.
hi friends i have tha same problem ,,,, need to read / write from SD .... did you solve it ???
