SD Card Read/ Write glitch
I'm trying to read temperature and humidity (T&H) values with a DHT22 sensor, then store those values in a .txt file with a SD card module (HiLetGo Micro SD TF). It's worth noting the Read/ Write sample code works fine. Also, I'm using the and Arduino Uno R3. Here are the issues:
  • When the code is adjusted to print T&H readings to the .txt file, nothing is saving on the .txt file.
  • There are instances where string values are succesffuly printed and saved to the .txt file but sensor readings are not.
  • The myfile.read(); function is not working for any instance besides in the sample code.
  • There are "remnants" of serial monitor outputs with new sketches uploaded to the Arduino Uno
I would greatly appreciate possible solutions to the issues mentioned above. Thank you!
Here is my code:
#include <SPI.h>
#include <SD.h>
#include <DHT.h>
#define DHTPIN 9
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
File myfile;
  while (!Serial)
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Initializing SD card...");
  if (!SD.begin(10))
    Serial.println("initialization failed!");
    while (1);
  Serial.println("Successful Initialization");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myfile = SD.open("test01.txt", FILE_WRITE);
  dht.begin();
  if (myfile)
    Serial.println("Successfully opened test");
    Serial.println("");
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  Serial.println("Void loop entered");
  myfile.println("Humidity - Temeperature(°F) - Heat Index(°F)");
  myfile.println("");
  for (int i = 0; i <= 4; i++)
    // If the file opened okay, write to it:
    // Reading temperature or humidity takes about 250 milliseconds!
    // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
    float h = dht.readHumidity();
    // Read temperature as Fahrenheit (isFahrenheit = true)
    float f = dht.readTemperature(true);
    // Compute heat index in Fahrenheit (the default)
    float hif = dht.computeHeatIndex(f, h);
    // Check if any reads failed and exit early (to try again).
    if (isnan(h) || isnan(f))
      Serial.println(F("Failed to read from DHT sensor!"));
      return;
      //Write to file
      myfile.print(h);
      myfile.print("%, ");
      myfile.print(f);
      myfile.print(", ");
      myfile.print(hif);
      myfile.println("");
      //Print to serial, expected values
      Serial.print(h);
      Serial.print("%, ");
      Serial.print(f);
      Serial.print(", ");
      Serial.print(hif);
      Serial.println("");
  Serial.println("Readings succesfully backed up.");
  Serial.println("Data points from file:");
  while (myfile.available())
    Serial.write(myfile.read());
    Serial.println("Check: Read func");
  Serial.println("");
  // close the file:
  myfile.flush();
  myfile.close();
  Serial.print("File closed");
  for (;;) {}
Here is the serial monitor:
22:48:18.368 -> Initializing SD card...
22:48:18.403 -> Successful Initialization
22:48:18.403 -> Successfully opened test
22:48:18.437 ->
22:48:18.437 -> Entered void loop
22:48:18.472 -> 27.10%, 81.68, 80.05
22:48:18.507 -> 27.10%, 81.68, 80.05
22:48:18.541 -> 27.10%, 81.68, 80.05
22:48:18.575 -> Readings succesfully backed up.
22:48:18.609 -> Data points from file:
22:48:18.643 ->
22:48:18.643 -> File closed
Hello there,
about myfile.read() not working: at the end of your for loop the file pointer will point to the end of the file, hence myfile.available() will return false. You can rewind the file pointer to point to the beginning of the file with myfile.seek(0).
About remnants of serial monitor output, I experience the same thing, I'm not sure if there is a way to get rid of those.
