I’ve got an interesting situation with my SD card reader / writer.
When the device is powered up it draws about 6 mA. However, once the first write has taken place then this drops to 0.6mA and stays there. I have more than one of these and they all behave the same. I may be wrong but to me this doesn’t seem normal?
I’ve attached some example code which is basically the datalogger demo with the sensor reading code removed and delay introduced.
SD card datalogger
This example shows how to log data from three analog sensors
to an SD card using the SD library.
The circuit:
* analog sensors on analog ins 0, 1, and 2
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created 24 Nov 2010
updated 2 Dec 2010
by Tom Igoe
This example code is in the public domain.
#include <SD.h>
// On the Ethernet Shield, CS is pin 4. Note that even if it's not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
const int chipSelect = 4;
// Some variables for timing
long previousMillis = 0; // will store last time the sensors were read
long interval = 60000; // interval at which to read sensors (milliseconds)
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
if(currentMillis - previousMillis > interval)
// make a string for assembling the data to log:
String dataString = "123456";
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
