I try to understand an example-file for my SD-Card reader. I can not see a loop in this example. Does that mean it reads 32 chars just once and displays it? How can I read longer files?
//mSD-Shield: OpenFileDemo (Display + SD-Card)
#include <MI0283QT2.h>
#include <SDcard.h>
MI0283QT2 lcd;
SDcard sd;
ISR(TIMER2_OVF_vect) //Timer 2 Interrupt, called every 1ms
static uint8_t count=1;
TCNT2 -= 250; //1000 Hz
if(--count == 0) //100 Hz
count = 10;
sd.service();
void ReadFile(char *file)
FIL fsrc; //file objects
FRESULT res; //result code
char buf[32]; //file buffer
UINT rd; //file R/W count
lcd.clear(RGB(255,255,255));
res = f_open(&fsrc, file, FA_OPEN_EXISTING | FA_READ);
if(res == FR_OK)
res = f_read(&fsrc, buf, sizeof(buf), &rd);
if(res == FR_OK)
if(rd >=sizeof(buf))
rd = sizeof(buf)-1;
buf[rd] = 0;
lcd.drawText(5, 5, buf, 1, RGB(0,0,0), RGB(255,255,255));
return;
f_close(&fsrc);
Serial.println("File not found!");
lcd.drawTextPGM(5, 5, PSTR("File not found!"), 1, RGB(0,0,0), RGB(255,255,255));
//init Serial port
Serial.begin(38400);
//init LCD
Serial.println("Init Display...");
lcd.init(4); //spi-clk = Fcpu/4
lcd.led(60); //backlight 0...100%
//init SD-Card
Serial.println("Init SD-Card...");
sd.init(4); //spi-clk = Fcpu/4
//init Timer2 for SD service routine
TCCR2B = (1<<CS22); //clk=F_CPU/64
TCNT2 = 0x00;
TIMSK2 |= (1<<TOIE2); //enable overflow interupt
//interrupts on
sei();
//clear screen
lcd.drawTextPGM(5, 5, PSTR("Mount card..."), 1, RGB(0,0,0), RGB(255,255,255));
if(sd.mount() == 0)
Serial.println("Read file...");
lcd.clear(RGB(0,255,0));
lcd.drawTextPGM(5, 5, PSTR("Read file..."), 1, RGB(255,255,255), RGB(0,255,0));
ReadFile("test.txt");
sd.unmount();
Serial.println("No card found!");
lcd.clear(RGB(255,0,0));
lcd.drawTextPGM(5, 5, PSTR("No card!"), 1, RGB(255,255,255), RGB(255,0,0));
