Hello,
(I am still a freshman...)
I am attempting to save numerical data in a SD card and retrieve it split into variables.
Number 1 into variable A
Number 2 into variable B
and
Number 3 into variable C
Below, you will see my sketch which I produced using bits from everywhere. (thanks to everybody)
Hence, my trouble is to find how to optimize / make my sketch better and foolproof.
Goal:
I am working on a system to check my electric bills, hence, log my electric power consumption and to avoid losing data whenever a power cut occurs (happens rarely, but it happens).
The following sketch is only a part of my final sketch (which I will certainly post here when it is finished).
So... if anyone is interested to have a look into my soup and to add salt and pepper, please feel free to do so.
--- for the moment, I used random numbers to simulate what has to be written on the SD card.
and ... I have a 3-phase electric system... (3x220v)
#include <SD.h>
SD.begin(4);
int A = 0;
int AA = 0;
int B = 0;
int BB = -1;
int C = 0;
int CC = -2;
char line[32];
size_t line_length = 0;
File file = SD.open("data.txt", FILE_WRITE | O_TRUNC); // clean file on the SD card
if (file) {
for (uint8_t i = 1; i <= 3; ++i) {
line_length = snprintf(line, sizeof(line), "%5hi", (int16_t)random(500, 600)); //formatting the random numbers and saving them on the SD card
Serial.print("Writing at position ");
Serial.print(i);
Serial.print(" : \"");
Serial.print(line);
Serial.println("\"");
file.println(line);
file.close(); //close the SD card file
line_length += 2; // count characters "\r\n" added by println
Serial.println(); //blank line to separate save and read/distributing into variables
// Following reads all lines from file
file = SD.open("data.txt");
if (file) {
while (file.available() >= line_length) {
static uint8_t line_id = 0;
file.seek(line_id * line_length); // go to line
//saving the 3 numbers in 3 different variables
if (AA == 0) {
A = file.parseInt();
AA = AA + 1;
BB = BB + 1;
CC = CC + 1;
if (BB == 0) {
B = file.parseInt();
BB = BB + 1;
CC = CC + 1;
if (CC == 0) {
C = file.parseInt();
CC = CC + 1;
file.read(line, line_length - 2); // read line without "\r\n"
line[line_length - 2] = '\0'; // make sure to add null character to make a valid C-string
// show that there are 3 numbers in the 3 variables - corresponding to the random numbers at the beginning
Serial.print("A = ");
Serial.println(A);
Serial.print("B = ");
Serial.println(B);
Serial.print("C = ");
Serial.println(C);
result:
12:05:23.940 -> Writing at position 1 : " 510"
12:05:23.972 -> Writing at position 2 : " 527"
12:05:23.972 -> Writing at position 3 : " 590"
12:05:23.972 ->
12:05:23.972 -> A = 510
12:05:23.972 -> B = 527
12:05:23.972 -> C = 590
another result:
12:08:20.552 -> Writing at position 1 : " 547"
12:08:20.552 -> Writing at position 2 : " 533"
12:08:20.552 -> Writing at position 3 : " 562"
12:08:20.597 ->
12:08:20.597 -> A = 547
12:08:20.597 -> B = 533
12:08:20.597 -> C = 562
Thanks a million...
