hello all,
i am building a data logger to save the operation time and still working on the basics features to save time with the RTC DS1302 and to write in a file in the SD Card.
my problem is after tracing the code i once i call
SD.Begin();
the time clock is return time as 2165-165-165 27:165:85
while before that it's working fine and returning correct time.
I am Using WeMos D1 for this project in order to send data through WiFi and to log it in case no connection.
#include <SD.h>
#include <SPI.h>
#include <ESP8266WiFi.h>
#include <stdio.h>
//#include <DS1302.h>
#include "RTClib.h"
const char* ssid = "123456789"
const char* password = "123456789"
int ledPin = 5;
WiFiServer server(80);
char servername[]="hidadacclrep.com"; // remote server we will connect to
WiFiClient client;
String result;
int CS_PIN = 15;
File file;
const int kCePin = 0; //5 Chip Enable
const int kIoPin = 2; //6 Input/Output
const int kSclkPin = 14; //7 Serial Clock
// Create a DS1302 object.
DS1302 rtc(kCePin, kIoPin, kSclkPin);
String dayAsString(const Time::Day day) {
switch (day) {
case Time::kSunday: return "Sunday";
case Time::kMonday: return "Monday";
case Time::kTuesday: return "Tuesday";
case Time::kWednesday: return "Wednesday";
case Time::kThursday: return "Thursday";
case Time::kFriday: return "Friday";
case Time::kSaturday: return "Saturday";
return "(unknown day)";
void printTime() {
// Get the current time and date from the chip.
Time t = rtc.time();
// Name the day of the week.
const String day = dayAsString(t.day);
// Format the time and date and insert into the temporary buffer.
char buf[50];
snprintf(buf, sizeof(buf), "%04d-%02d-%02d %02d:%02d:%02d",
t.yr, t.mon, t.date,
t.hr, t.min, t.sec);
// Print the formatted string to serial so we can see the time.
Serial.println(buf);
char* getTime() {
//Get the current time and date from the chip.
char buf[50];
return buf;
//} // namespace
//Serial.begin(9600);
rtc.halt(false);
rtc.writeProtect(true);
delay(2000);
initializeWiFi();
result="";
//sendGET();
//printTime();
initializeSD();
printTime();
createFile("test1.txt");
printTime();
// file.print(v);
file.println("This is sample text!");
file.println(ESP.getChipId());
file.println(getTime()); file.println(getTime());
Serial.println(ESP.getChipId());
// delay(1000);
Serial.println("hello");
Serial.println(file.read());
closeFile();
// closeFile();
printTime();
void deleteHttpHeader()
if(result.endsWith("Content-Type: text/plain"))
result="";
void sendGET() //client function to send/receive GET request data.
if (client.connect(servername, 80)) { //starts client connection, checks for connection
Serial.println("connected");
client.println("GET /datalog.aspx?Deviceid=" + String(ESP.getChipId()) + " HTTP/1.1"); //download text
client.println("Host: hidadacclrep.com");
client.println("Connection: close"); //close 1.1 persistent connection
client.println(); //end of get request
else {
Serial.println("connection failed"); //error message if no client connect
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
char c = client.read(); //gets byte from ethernet buffer
result = result+c;
deleteHttpHeader();
Serial.println(c);
Serial.println(result);
WiFiClient client;
String result;
client.stop(); //stop client
void initializeWiFi()
delay(10);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
Serial.print(F("Setting static ip to : "));
// Serial.println(ip);
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
//IPAddress subnet(255, 255, 255, 0); // set subnet mask to match your network
//WiFi.config(ip, gateway, subnet);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address
Serial.print("Use this URL : ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
digitalWrite(ledPin, HIGH);
void initializeSD()
printTime();
Serial.println("Initializing SD card...");
printTime();
//pinMode(CS_PIN, OUTPUT);
printTime();
if (SD.begin())
Serial.println("SD card is ready to use.");
Serial.println("SD card initialization failed");
return;
printTime();
int createFile(char filename[])
file = SD.open(filename, FILE_WRITE);
if (file)
Serial.println("File created successfully.");
return 1;
} else
Serial.println("Error while creating file.");
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
return 0;
int writeToFile(char text[])
if (file)
file.println(text);
Serial.println("Writing to file: ");
Serial.println(text);
return 1;
} else
Serial.println("Couldn't write to file");
return 0;
void closeFile()
if (file)
file.close();
Serial.println("File closed");
int openFile(char filename[])
file = SD.open(filename);
if (file)
Serial.println("File opened with success!");
return 1;
} else
Serial.println("Error opening file...");
return 0;
String readLine()
String received = "";
char ch;
while (file.available())
ch = file.read();
if (ch == '\n')
return String(received);
received += ch;
return "";
