SD card: salva su sd soltanto i primi 14 valori
Uso arduino uno R3 e ide 1.0.3
ho una wireless sd shield montata su e diversi sensori.
Vorrei salvare i dati su sd ma mi accorgo da seriale che, a partire dal 15esimo valore, non apre il file data.txt.
Cosa può essere?
Senza codice non possiamo saperlo neanche noi :wink:
Se non hai una shield Wifi col vecchio firmware puoi tranquillamente aggiornare l'IDE alla 1.0.6 o alla beta 1.5.8.
Inoltre senza vedere lo sketch è difficile risponderti.
Eccolo: è abbastanza lungo ed occupa 21.608 bytes
#include <dht.h> //library for DHT22
#include "kSeries.h" //library for K-30_CO2_sensor
#include <SD.h> //library to write to SD card
dht DHT;//DHT22
#define DHT22_PIN 5 //DHT22 is plugged into pin 5 on the Arduino
#define analogPinForRV    1 // MD wind sensor. RV is plugged into pin A1 on the Arduino
#define analogPinForTMP   0 // MD wind sensor. TMP is plugged into pin A0 on the Arduino
const float zeroWindAdjustment =  .2; //MD wind sensor. To calibrate your sensor, put a glass over it, but the sensor should not be touching the desktop surface however. Adjust the zeroWindAdjustment until your sensor reads about zero with the glass over it.
int TMP_Therm_ADunits; //MD wind sensor. temp termistor value from wind sensor
float RV_Wind_ADunits; //MD wind sensor. RV output from wind sensor
float RV_Wind_Volts; //MD wind sensor.
unsigned long lastMillis; //MD wind sensor.
int TempCtimes100; //MD wind sensor.
float zeroWind_ADunits; //MD wind sensor.
float zeroWind_volts; //MD wind sensor.
float WindSpeed_MPH; //MD wind sensor.
float A; //MD wind sensor.
float B; //MD wind sensor.
kSeries K_30(6,8); //Create K30 instance on pin 6 & 8
int LDR_A0 = A2; //photoresistor is plugged into analog pin 2 on the Arduino
float Vin_div_values = 0.004882812;  //= 5/1024 dove: 5 =Vin e 1024 aono i valori massimi di analogRead
float Vout0 = 0;
float R0 = 0;
float R10k0 = 9739; //resistor in ohm measured
float R1_0 = 94000;
float Lux0 = 0;
float a = 0.7;
const int thermistor = A3; //thermistor10k is plugged into analog pin 3 on the Arduino
File myFile; //SD card: define myFile
  pinMode(10, OUTPUT); // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
  if (!SD.begin(4)) {
  Serial.println("initialization failed!");
  return;
  Serial.println("initialization done.");
  myFile = SD.open("data.txt", FILE_WRITE); // open the file. note that only one file can be open at a time,
  // if the file opened okay, write to it:
  if (myFile) {
  myFile.println("DHT22_H(%), DHT22_T(C), Thermistor_T(C), AS(MPH), Co2(ppm), LDR (lx) ");
  myFile.close();
    // if the file didn't open, print an error:
    Serial.println("error opening data.txt");
  //Serial.println();
  //Serial.println("DHT22_H(%), DHT22_T(C), Thermistor_T(C), AS(MPH), Co2(ppm), LDR (lx) ");
  int chk = DHT.read22(DHT22_PIN); //DHT11 reads data
  //Serial.print(DHT.humidity, 2); //DHT11 prints humidity value in °C. Il numero indica le cifre decimali del DHT22
  //Serial.print(",       "); // prints a comma and a space
  //Serial.print(DHT.temperature, 2); //DHT11 prints temperature value in °C. Il numero indica le cifre decimali del DHT22
  float t = 0.22+((3976/log(((10000*5.0/((5.0 * analogRead(thermistor))/1024))-10000)/0.016167))-273.15); // read temperature from thermistor (+0.22 to align the values)
  //Serial.print(t); // prints temperature value in °C.
  //below instructions for the MD wind sensor:
  if (millis() - lastMillis > 200){      // read every 200 ms - printing slows this down further
    TMP_Therm_ADunits = analogRead(analogPinForTMP);
    RV_Wind_ADunits = analogRead(analogPinForRV);
    RV_Wind_Volts = (RV_Wind_ADunits *  0.0048828125);
//define the variable A and B:
  B = 0.00485785789945844;
  A= -4.089 * RV_Wind_Volts * RV_Wind_Volts + 22.697 * RV_Wind_Volts - 29.371;
    // these are all derived from regressions from raw data as such they depend on a lot of experimental factors
    // such as accuracy of temp sensors, and voltage at the actual wind sensor, (wire losses) which were unaccouted for.
    TempCtimes100 = (0.005 *((float)TMP_Therm_ADunits * (float)TMP_Therm_ADunits)) - (16.862 * (float)TMP_Therm_ADunits) + 9075.4;
    zeroWind_ADunits = -0.0006*((float)TMP_Therm_ADunits * (float)TMP_Therm_ADunits) + 1.0727 * (float)TMP_Therm_ADunits + 47.172;  //  13.0C  553  482.39
    zeroWind_volts = (zeroWind_ADunits * 0.0048828125) - zeroWindAdjustment;
    WindSpeed_MPH =  pow(((RV_Wind_Volts - zeroWind_volts) /.2300) , 2.7265);
    //Serial.print((float)WindSpeed_MPH);
   //end instructions for the MD wind sensor
  double co2 = K_30.getCO2('p'); // k30 sensor. Get CO2 value from sensor
  //Serial.print("Co2 ppm = "); //k30 sensor. Print the value on Serial
  //Serial.print(co2); //k30 sensor. Prints the value on Serial
  Vout0 = (float(Vin_div_values * analogRead(LDR_A0)));
  R0 = ((5/Vout0*R10k0)-R10k0);
  Lux0 = pow((R0/R1_0),(1/-a));
  //Serial.println(Lux0);
  //instruction to write all data to sd card
  myFile = SD.open("data.txt", FILE_WRITE); //first open the file.
  //then, write on it
  if (myFile) {
  myFile.print(DHT.humidity, 2); //DHT22 prints on the SD Card humidity value in °C. Il numero indica le cifre decimali del DHT11
  myFile.print(",       "); // prints on the SD Card a comma and a space
  myFile.print(DHT.temperature, 2); //DHT22 prints on the SD Card temperature value in °C. Il numero indica le cifre decimali del DHT11
  myFile.print(t); // thermistor prints on the SD Card temperature value in °C.
  myFile.print((float)WindSpeed_MPH); //MD wind speed prints on the SD Card the value
  myFile.print(co2); //k30 sensor prints on the SD Card the value
  myFile.println(Lux0); //photoresistor prints on the SD Card the value
  myFile.close();
  Serial.println("data printed on data.txt");
delay(10000);
Non riesco a compilarlo perché mi mancano 2 lib, ma sarebbe da vedere il consumo di RAM. Intanto prova utilizzando la funzione F() per tutte le stringhe costanti. Ad esempio da così:
a così:
Serial.println(F("initialization failed!"));
Per ridurre il consumo di RAM.
Ok, ho utilizzato per tutti i Serial.print la funzione F. Gli altri variabili li avevo già disattivati facendoli diventare dei commenti. Ora arrivo a 17 scritture poi "error opening data.txt".
leo72:
Ecco il link alle 3 librerie:
https://www.dropbox.com/s/fubaocxf0wo8abh/SD.zip?dl=0
Ok, ho risolto sostituendo la libreria di default SD con SdFat.
