SD Card. see the card but not the volume when other spi devices are connected
I have a Ethernet Shield, And a SPI TFT screen.
When i load the default cardinfo sketch and add the lines for the spi pins for the screen as shown in the code
I have both connected and the TFT and the Ethernetshield.
when the tft is connected i can see the card but not the volume. can anyone explain it.
when i disconnect the tft the SD card can be read.
the screen is functioning ok even when the ethernet shield is connected.
#include <SPI.h>
#include <SD.h>
#define RA8875_CS_Pin 32
#define RA8875_Reset_Pin 30
#define SD_chipSelect 4
#define Ethernet_chipSelect 10
Sd2Card card;
SdVolume volume;
SdFile root;
{  Serial.begin(115200);
   Serial.print("\nInitializing SD card...");
  pinMode(30, OUTPUT);
  pinMode(RA8875_CS_Pin, OUTPUT);
  pinMode(SD_chipSelect, OUTPUT);
  pinMode(Ethernet_chipSelect, OUTPUT);
  SPI.setClockDivider(SD_chipSelect, 21);
  digitalWrite(SD_chipSelect, HIGH);
  SPI.setClockDivider(Ethernet_chipSelect, 84);
  digitalWrite(Ethernet_chipSelect, HIGH);
  SPI.setClockDivider(RA8875_CS_Pin, 1);
  digitalWrite(RA8875_CS_Pin, HIGH);
  if (!SD.begin(SD_chipSelect)) {
    Serial.println("SD initialization failed!");
    Serial.println("SD initialization done.");
 // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, SD_chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card is inserted?");
    Serial.println("* Is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    return;
    Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("\nCard type: ");
  switch (card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    return;
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("\nVolume type is FAT");
  Serial.println(volume.fatType(), DEC);
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize *= 512;                            // SD card blocks are always 512 bytes
  Serial.print("Volume size (bytes): ");
  Serial.println(volumesize);
  Serial.print("Volume size (Kbytes): ");
  volumesize /= 1024;
  Serial.print("Volume size (Mbytes): ");
  volumesize /= 1024;
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
//   When Ethernet shield and TFT are connected.
Card type: SDHC
// Only Ethernet Shield connected
Card type: SDHC
Volume type is FAT32
Volume size (bytes): 3711934464
Volume size (Kbytes): 3624936
Volume size (Mbytes): 3539
TEST.TXT      2000-01-01 01:00:00 162
TROMMEL.TXT   2000-01-01 01:00:00 55
DATALOG.TXT   2000-01-01 01:00:00 1681947
jl-p:
That form of the SPI.setClockDivider() only works on the Arduino DUE:
O yeah sorry
I have a due.
Forgot to mention it
i noticed that the issue only exist with sdhc and not with sd2 cards
