Only got the error message once ....
When I go to the Serial Monitor now, it comes up blank
on the SD card I have
Siren ..... WAV file
TMRpcm-1.0.0 ....... File folder
with test.wav zip file included
Thanks, Bruce in Mount Airy, MD
The program is looking explicitly for a file named test.wav. Unless something very special is going on (I doubt it) then it will not open the zip file , find it and play it.
Extract test.wav from the zip file and put it in the root folder of the SD card.
OK, think I changed it but still no sound and no error message. I have attached a photo of the directory, I think .... is this the way it should be? Thanks, Bruce in Mount Airy, MD
Yes, that is on the SD card (G). I am very new to this and do not have much programming in my background, so please explain "all those source files" means. should the wav file be the only thing on the SD card? Thanks
Do you know what an 8.3 filename is? You may need to use 8.3 filenames, which means all
UPPERcase, upto 8 characters before the '.', upto 3 characters after.
MarkT:
Upper case is NOT a requirement for 8.3 names. Never has been. .txt has been a perfectly valid extension since Bill Gates first started writing operating system software.
