I hate to throw this one out there - it seems there are a few people have an almost similar experience, but nothing quite the same that I could find.
My Mega2560 is connected to a 3.2" TFT via a display shield. These are all cheap versions for a beginner like me.
Essentially, when I run the code from one of the examples available in the Arduino IDE, they run perfectly well. No problems at all. SD card is opened, file is created, written to, read from, CardInfo is found - the whole lot works no problem.
But then when I run my code, the first card initialisation is good (this takes place in SETUP), but then subsequent calls to the SD in LOOP invariably fail.
The example code I found closest resembled my situation was the Datalogger example (because it performs a card initialisation in SETUP, then uses LOOP to write to the card). I changed the chipSelect pin to 53 (the correct number for my setup). This example works flawlessly for me. I check the SD card in Windows and all the data is there.
As a result, I pretty much pilfered all the 'right' bits of code I could from the above and put them into my program. But it just does not work.
Incredibly frustrating!
My code is below:
#include <SPI.h>
#include <SD.h>
#include <OneWire.h>
#include <DallasTemperature.h>
// This program requires the UTFT library.
#include <UTFT.h>
#include <UTFT_DLB.h>
// Declare which fonts we will be using
extern uint8_t SevenSeg[];
extern uint8_t SevenSegSmall[];
extern uint8_t BigSymbols[];
extern uint8_t SmallSymbols[];
extern uint8_t DejaVuSans18[];
extern uint8_t DejaVuSans24[];
// Remember to change the model parameter to suit your display module!
UTFT_DLB tft(ITDB32S,38,39,40,41);
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 8
#define TEMPERATURE_PRECISION 9
#define BAUD_RATE 115200
// (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
int x=0;
float inTemp;
float outTemp;
float ambientTemp;
float EGT;
float effValue;
int effValueScreen;
// For the pressure sensor (MPX5500DP)
int rawValue = 0; // Variable stores value coming from the sensor
int offset = 38; // zero pressure adjust
int fullScale = 500; // max pressure (span) adjust
float boost; // final pressure
//For the plotting of the graph
int previous_boostYaxis;
int boostY_axis=238;
int previous_ambientTempYaxis;
int ambientTempY_axis=238;
int previous_inTempYaxis;
int inTempY_axis=238;
int previous_outTempYaxis;
int outTempY_axis=238;
int x_axis=0;
// position of the line on screen
int xPos = 0;
int plot;
File dataFile;
const int chipSelect = 53;
void setup(void)
// start serial port
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// Initialize screen
tft.InitLCD();
tft.clrScr();
// Start up the OneWire library
sensors.begin();
sensors.setResolution(9);
// write the static content to the screen
// set the font color to white
tft.setColor(255, 255, 255);
// draw some boxes
tft.setColor(80,80,80);
tft.fillRect(0,0,319, 30);
tft.setColor(150,150,150);
tft.drawLine(0,30,319,30);
// set the font size
tft.setFont(DejaVuSans18);
// write, colour & position the text labels
tft.setColor(0, 255, 0);
tft.print("Amb", 5, 40);
tft.setColor(255, 0, 0);
tft.print("Pre", 120, 40);
tft.setColor(0, 0, 255);
tft.print("Post", 230, 40);
tft.setColor(200, 200, 200);
tft.print("Eff (%)", 60, 70);
tft.print("Boost", 225, 70);
tft.drawLine(0,148,319,148);
tft.setColor(30,30,30);
tft.fillRect(0,149,319,239);
// Check the SD Card
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
//------------------ READ SENSORS AND PERFORM EFFICIENCY CALC ----------------------------
void loop(void)
unsigned long start=millis();
sensors.requestTemperatures(); // Send the command to get temperatures
inTemp = (sensors.getTempCByIndex(0)); //Put sensor data into variables
outTemp = (sensors.getTempCByIndex(1));
ambientTemp = (sensors.getTempCByIndex(2));
effValue = ((inTemp-outTemp) / (inTemp-ambientTemp)*100); //calculate cooler efficiency
effValueScreen = effValue; //move float value to int
effValueScreen = constrain(effValueScreen, 0, 100 ); //Hold value (percentage) to within 0-100
//------------------ READ BOOST THEN GRAPH IT ------------------------------
// For reading the boost...
rawValue = analogRead(A0);
boost = (rawValue - offset) * 500.0 / (fullScale - offset); // pressure conversion
boost=map(boost, 0, 300, 0, 150);
boost = constrain(boost, 0, 30 ); //Hold value (psi) to within 0-30
// For graphing the boost...
checkX_axis(); //Check to make sure the 'x' axis is still on-screen
previous_boostYaxis=boostY_axis;
boostY_axis=(239-boost*3);
plotBoost(previous_boostYaxis,boostY_axis);
previous_inTempYaxis=inTempY_axis;
inTempY_axis=(239-inTemp*1.5);
plotInTemp(previous_inTempYaxis,inTempY_axis);
previous_outTempYaxis=outTempY_axis;
outTempY_axis=(239-outTemp*1.5);
plotOutTemp(previous_outTempYaxis,outTempY_axis);
previous_ambientTempYaxis=ambientTempY_axis;
ambientTempY_axis=(239-ambientTemp*1.5);
plotAmbientTemp(previous_ambientTempYaxis,ambientTempY_axis);
graphErase();
//setup screen variable colour scheme
tft.setBackColor(0,0,0);
//print variable values to screen
tft.setFont(SevenSegSmall);
// String ambientTempStr=String(ambientTemp);
tft.printNumI(ambientTemp, 60, 35);
tft.printNumI(inTemp, 165, 35);
tft.printNumI(outTemp, 285, 35);
//Efficiency and Boost variables get a bigger font
tft.setFont(SevenSeg);
tft.printNumI(effValueScreen, 35, 90,1);
tft.printNumI(boost, 240, 90);
writeSD();
//---------------- SETUP THE TOUCH AREAS OF THE SCREEN FOR PAGING ---------------
//tft.setFont(BigSymbols);
//tft.setColor(190,190,190);
//tft.setBackColor(80,80,80);
//tft.print("R", 0,0); //arrow left
//tft.print("S", 288,0); //arrow right
unsigned long finish=millis();
unsigned long total=finish-start;
Serial.print("Time: ");
Serial.println(total);
void checkX_axis(){
x_axis++;
if(x_axis==319){ //returns the graph to the left of the screen to scroll across again
tft.fillRect(0,149,2,239);
x_axis=0;
void graphErase(){
tft.drawLine(x_axis+12, 149,x_axis+12,239);
tft.fillRect(x_axis+1, 149,x_axis+11,239);
void plotBoost(int previous_Yaxis,int y_axis){
tft.drawLine(x_axis-1,previous_boostYaxis , x_axis, boostY_axis); // x axis
void plotAmbientTemp(int previous_ambientTempYaxis,int ambientTempY_axis){
tft.drawLine(x_axis-1,previous_ambientTempYaxis , x_axis, ambientTempY_axis); // x axis
void plotInTemp(int previous_inTempYaxis,int inTempY_axis){
tft.drawLine(x_axis-1,previous_inTempYaxis , x_axis, inTempY_axis); // x axis
void plotOutTemp(int previous_outTempYaxis,int outTempY_axis){
tft.drawLine(x_axis-1,previous_outTempYaxis , x_axis, outTempY_axis); // x axis
void writeSD(){
dataFile = SD.open("sensorData.txt", FILE_WRITE);
Serial.println(dataFile);
if (dataFile)
dataFile.println(ambientTemp);
Serial.print(",");
dataFile.print(inTemp);
Serial.print(",");
dataFile.print(outTemp);
Serial.print(",");
dataFile.print(effValue);
Serial.print(",");
dataFile.print(boost);
Serial.print(",");
dataFile.close(); // close the file:
Serial.println("data written\n\n");
} else
// if the file didn't open, report an error:
Serial.println("\nerror opening the text file!");
// re-open the text file for reading:
dataFile = SD.open("sensorData.txt");
if (dataFile)
Serial.println("sensorData.txt:");
// read all the text written on the file
while (dataFile.available())
Serial.write(dataFile.read());
// close the file:
dataFile.close();
} else
Serial.println("rror opening the file!\n");
If anyone can point out to me where I have gone wrong I would be forever grateful!
