SD card wiriting const char* error
Hello ,
I try to use the SD card in combination with an ESP32 Hardware is connected and it is working.
But when I try to run the next software from ESP32: Guide for MicroSD Card Module Arduino | Random Nerd Tutorials
with the function // appendFile(SD, "/test.txt", "button2 active\n "); it is running
when I try to change to appendFile(SD, "/test.txt", dataString);
I get the error message:
RTCenSD.ino:101:49: error: invalid cast from type 'String' to type 'const char*'
What is wrong ?
#include<SPI.h>
#include<SD.h>
#include<Wire.h>
#include"RTClib.h"
#include<CircularBuffer.h>
RTC_DS1307 rtc;
String timestring;
int16_t interval = 1;  //Log to SD Card every 1 seconds
long timer;
#define chipSelect 5 //SD card
String DT[10];
int16_t i = 0;
void setup(){
  delay(2000);
  if(!SD.begin(chipSelect)) {  //SD CardSerial.println("Initializing SD card...");
    Serial.println("SD Card error");
    return;
  }else  Serial.println("card initialized");
  //RTC startup
  if(! rtc.begin()) Serial.println("No RTC found");
  else Serial.println("RTC clock found");
  if(! rtc.isrunning()) Serial.println("RTC is not configured");
  //initialize timestring-array
  for(int j = 0; j < 10; j++) {
    DT[j] = "99-99-99 99:99:99";
  timer = millis();
  writeFile(SD, "/test.txt", "new file!!!\n ");
void loop(){
  // push each interval one dataset to queue
  if((timer + interval * 1000) < millis()) {
    timer = millis();
    get_time(); //Get time from RTC
    i++;
    if(i==10)i=0;
    write_data();   //Write value and Time to SD
void get_time(){ //Read Time from RTCDateTime now = rtc.now();
  timestring = now.day();     timestring += "-";
  timestring += now.month();  timestring += "-";
  timestring += now.year();   timestring += " ";
  timestring += now.hour();   timestring += ":";
  timestring += now.minute(); timestring += ":";
  timestring += now.second();  DT[i] = timestring;
  //Serial.println("i= "+ String(i) + " en DTstring= "+ DT[i]); //Serial.println("TS: "+ timestring);
void appendFile(fs::FS &fs, const char * path, const char * message) {
  Serial.printf("Appending to file: %s\n", path);
  File file = fs.open(path, FILE_APPEND);
  if (!file) {
    Serial.println("Failed to open file for appending");
    return;
  if (file.print(message)) {
    Serial.println("Message appended");
    Serial.println("Append failed");
  file.close();
void writeFile(fs::FS &fs, const char * path, const char * message) {
  Serial.printf("Writing file: %s\n", path);
  File file = fs.open(path, FILE_WRITE);
  if (!file) {
    Serial.println("Failed to open file for writing");
    return;
    Serial.println("File written");
    Serial.println("Write failed");
  file.close();
void write_data(){ //Write to SD card
  File dataFile = SD.open("/test.txt", FILE_WRITE);
  int16_t j = 0;
      String dataString="Datum en tijd is "+ DT[0] + "\r\n";
      Serial.println(dataString);
    dataFile.close();
The error message seems clear
The function expects an array of chars as the second argument but you are providing a String
The String library has a function named toCharArray() which will presumably do the conversion, but I am not a user of Strings so could be wrong
The error message is very clear:
The function you're using requires a "const char *" parameter, while you're using a "String":
if you are unsure of the difference perhaps this will help.
You shouldn't use this:
but either use a "char*" variable buffer like this one (I dimensioned it to 30, meaning the total string length must be 29 characters or less, including the trailing CR and LF):
  char dataString[30];
  strcpy(dataString, "Datum en tijd is ");
  strcat(dataString, DT[0]);
  strcat(dataString, "\r\n");
or use sprintf() to build the line in a single statement:
  sprintf(dataString, "Datum en tijd is %s\r\n", DT[0]);
or convert "String" into "char*" using "c_str()" method:
      appendFile(SD, "/test.txt", dataString.c_str());
Thanks docdoc that is a clear explanation.
you can use this:
instead of yours:
