I have tried to use an SD card with an Ardino and had no luck, whenever I connected my card to the holder the board shorted out (Most likely a wiring problem).
I cannot find any clear instructions of how to use an SD card (preferably SDHC) with an Arduino mega (I am using a DFRduino, it is an exact clone).
For the project I am working on I am already using pins 0 to 12, 14 to 17 and 22 to 28, I hope this isn't a problem and I may be able to move them if necessary.
There are neat solutions allowing you to plug a USB thumb-drive (memory stick) into an Arduino. They take care of all the nasty USB AND filing system stuff.... think "Ascii command driven external storage". Search with Google on "VDIP-1 USB Arduino" for lots more information. About $25. Supplier: www.vinculum.com/prd_vdip1.html
Does this work via serial with just tx and rx (and power) connected to the board and also are there limits to the flash drive capacity and filesystem etc?
All of the Rogue Robotics solutions are way too expensive. I like the idea of using the VDIP 2 and have found out that it works with fat 12, 16 and 32 but I am not sure if it works with multiple partitions.
I will buy it and use it if I know that it works quite easily with an arduino.
