SD card write not working [not hardware issue]
Hello! I'm trying to set up a datalogger (time with real time clock module, temp, humidity, photocell reading) with an Arduino Uno. I think I've got everything physically connected correctly, which I know because when I test every individual part, it all works. The SPI module works if I use a default test sketch, but it doesn't work with my datalogger sketch. I have formatted the 4gb SD card as recommended on this forum. The sensors all work, the SPI module will write to the SD card using the default sketch, but when I use the same hardware and the same connections with my own sketch, it's not working, which leads me to believe it's a programming problem. I've tried comparing it line by line to the test sketch but I can't see what's different. Please could you advise what I should look for? Thank you!
This is my sketch that is not working:
#include <SPI.h>              // include Arduino SPI module (SD card module) library
#include <SD.h>               // include Arduino SD library
const int chipSelect = 10; //SD card CS pin connected to pin 10 of Arduino
File myFile;
int photocellPin = A0;     // the cell and 10K pulldown are connected to a0
int photocellReading;     // the analog reading from the sensor divider
int LED1 = 7;          // LED connected to pin 7
int LED2 = 6;
int LED3 = 5;
int LED4 = 4;
int LED5 = 3;
int LED6 = 8;
int LED_POWER = 1;
void setup(){
  digitalWrite(LED_POWER, HIGH);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Initialize_SDcard(); // Calls the function Initialize_SDcard()
  //pinMode(10, OUTPUT); // Sets the pins for SD card and LEDs as outputs
  pinMode(8, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(1, OUTPUT);
  //digitalWrite(10, HIGH); // Tells Arduino that the SD card pin is an output
void Initialize_SDcard()
  if (!SD.begin(chipSelect)) // Checking if the SD card is missing
    Serial.println("Card failed, or not present"); // Error message if SD card missing
    return;
    myFile = SD.open("datalogger.txt", FILE_WRITE); // New file created if SD card not missing
    if (myFile) {
      myFile.println("Time, Temperature, Humidity, Photocell"); //Write the first row of the file with headings
      myFile.close();
    else {
      Serial.println("Error opening datalogger.txt");
void Read_Values()
  photocellReading = analogRead(photocellPin);  // The value of the photocell will be saved as variable photocellReading
  Serial.print("  photocell:");
  Serial.println(photocellReading);
void Write_SDcard()
  myFile = SD.open("datalogger.txt", FILE_WRITE); // The file name for the SD card file
  if (myFile) // The section below will save temp, humidity & photocell value to SD card
    myFile.println(photocellReading);
    myFile.close(); //Close the file
    Serial.println("SD card writing failed");
  }// Error message if the SD card doesn't work
void loop(){
    Read_Values(); // Launches the Read_Values() function
    Write_SDcard();   // Launches the Write_SDcard() function
    if (photocellReading > 900) // If it gets extremely dark, one LED will flash
      digitalWrite(LED1, HIGH);
      digitalWrite(LED2, LOW);
      digitalWrite(LED3, LOW);
      digitalWrite(LED4, LOW);
      digitalWrite(LED5, LOW);
      digitalWrite(LED6, LOW);
      delay (500);
      digitalWrite(LED1, LOW);
      delay(5000);
  else if (photocellReading > 800) // This should be the baseline for normal light
    else if (photocellReading > 700)
      digitalWrite(LED2, HIGH);
    else if (photocellReading > 600)
      digitalWrite(LED3, HIGH);
    else if (photocellReading > 500)
      digitalWrite(LED4, HIGH);
     else if (photocellReading > 400)
      digitalWrite(LED5, HIGH);
     else if (photocellReading > 300)
      digitalWrite(LED6, HIGH);
    else if (photocellReading > 0) // If light levels are extremely high, all 5 LEDs flash at 0.5 second intervals
      delay (500);
      delay (500);
This is the test one I used that IS working:
#include <SPI.h>
#include <SD.h>
File myFile;
while (!Serial) {
Serial.print("Initializing SD card...");
if (!SD.begin(10)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println("This is a test file 2:)");
myFile.println("testing 1, 2, 3.");
for (int i = 0; i < 20; i++) {
myFile.println(i);
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// nothing happens after setup
The SD library requires you to use 8.3 filenames
THANK YOU! Oh gosh, so simple. I've spent ages trying to debut this and it was a file name. Thanks for the quick support.
It is a common problem so not hard to spot and I am glad that it worked
Good luck with your project
