SD card writing: very strange behaviour
I am developing a simple project to measure 4 temperature values and store them in an SD card. Everything is working ok but the SD card. Here is my code:
#include <OneWire.h> // This is for the temperature sensors
#include <DallasTemperature.h> // This is for the temperature sensors
#include <Wire.h> // This is for the RTC
#include "RTClib.h" // This is for the RTC
#include <SD.h>
#define SENSORS_PIN 9
#define N_SENSORS 4
#define SD_BUSSY_LED_PIN 8
#define DATA_FILE_NAME "datalog.txt" // Max 8 chars of name + 3 of extension!!!
OneWire oneWireObject(SENSORS_PIN);
DallasTemperature sensorDS18B20(&oneWireObject);
// Declaramos un RTC DS3231
RTC_DS3231 rtc;
void SD_indicate_busy(int i);
	pinMode(SD_BUSSY_LED_PIN, OUTPUT);
    sensorDS18B20.begin();
	// RTC initialization ----------
	Serial.print("Initializing RTC... ");
	delay(100);
	if (! rtc.begin()) {
		Serial.println("ERROR: Cannot find RTC module!");
		while (1);
	//~ rtc.adjust(DateTime(F(__DATE__), F(__TIME__))); // Uncomment this line to set the RTC time to the compilation time.
	Serial.println("OK");
	// SD card initialization ------
	Serial.print("Initializing SD card... ");
	delay(100);
	if (!SD.begin(4)) {
		Serial.println("ERROR: SD card failed, or not present");
		while (1);
	int k;
	int current_day = -1;
	DateTime now;
	File dataFile;
	while (1) {
		// Take measurements ------------------------------------
		sensorDS18B20.requestTemperatures();
		now = rtc.now();
		// Write data to file -----------------------------------
		SD_indicate_busy(1);
		dataFile = SD.open(DATA_FILE_NAME, FILE_WRITE);
		if (dataFile) { // If the file is available, write to it:
			dataFile.print(now.year());
			dataFile.print('\t');
			dataFile.print(now.month());
			dataFile.print(now.day());
			dataFile.print(now.hour());
			dataFile.print(now.minute());
			dataFile.print(now.second());
			for (k=0; k<=N_SENSORS-1; k++) {
				dataFile.print(sensorDS18B20.getTempCByIndex(k));
			dataFile.print('\n');
			dataFile.close();
			SD_indicate_busy(0);
			Serial.print("Data has been saved! ");
			Serial.print(now.year());
			Serial.print(" ");
			Serial.print(now.month());
			Serial.print(" ");
			Serial.print(now.day());
			Serial.print(" ");
			Serial.print(now.hour());
			Serial.print(" ");
			Serial.print(now.minute());
			Serial.print(" ");
			Serial.println(now.second());
		} else { // if the file isn't open, pop up an error:
			Serial.println("ERROR: Cannot open file in SD card");
			while (1);
void SD_indicate_busy(int i) {
	if (i!=0)
		digitalWrite(SD_BUSSY_LED_PIN, HIGH);
		digitalWrite(SD_BUSSY_LED_PIN, LOW);
After I have formatted the SD card in FAT16 using Gparted (in Ubuntu), when I put it in the card reader and run the Arduino program what I get through the serial monitor is:
Initializing RTC… OK
Initializing SD card… OK
and the SD card content, viewed in the PC, is:
The file “DATALOG.TXT” is empty. The SD card is locked in “only read mode”.
Exactly the same happens formatting in FAT32.
I have changed the SD card module for a new one and the same. I have checked connections many times. The SD card works perfectly in my computer. I can save and read files perfectly well from Ubuntu.
What can be happening?
The problem was "magically solved". I change the wires and it began to work. Maybe one of them was not contacting properly, I don't know.
