All
I have combined different code which work by themselves. However when combined, the servo does not move despite what appears to be the code working ..
I do not doubt the servo itself as I it works using the arduino examples
The code receives an IR remote signal ok and interprets it using a case statement ok. Once received the code reads the SD Card ok and plays a corresponding sound ok. I then added instruction for the servo to move for "case 0x3D9AE3F7". Using the serial monitor I see the variable "pos" changes as expected. "pos"is required to move the servo (myServo.write(pos)).... but the servo doesn't move ??
Am I missing something ?
Here is the code:
// Title: IR Reader and Action Trigger (inc Sound Files on SD Card) + TBC
// Date: 31 May'15
// Notes: Compiled ok and worked on 31May after adding case/switch routine from Tronixstuff.com
// IRremote Libraries
#include <IRremote.h>
#include <IRremoteInt.h>
int RECV_PIN = 7; // using digital pin 7 on Uno for IR Rx. Chgd from 11 to 7 as conflict'd with SDcard MOSI pin
IRrecv irrecv(RECV_PIN);
decode_results results;
// SD Card Libraries
#include <SPI.h>
#include <SD.h>
#define SD_ChipSelectPin 4 // using digital pin 4 on arduino nano 328 for SD card select (CS)
#include <TMRpcm.h> // also need to include this library...
TMRpcm tmrpcm; // create an object for use in this sketch
char mychar;
// Servo Libraries
#include <Servo.h> // imports servo library
Servo myServo; // associated myservo object will all resources in servo library
int pos = 0; // variable to store the servo position
{ // put your setup code here, to run once:
irrecv.enableIRIn(); // start the receiver
tmrpcm.speakerPin = 9; // using digital pin 9 on Uno, Nano (11 on Mega) for Spkr output
//tmrpcm.setVolume(7); // **set volume level - 0 (low) to 7 (high). (added 310515 if doesnt work delete)**
myServo.attach(6); // attaches the servo on pin 6(was 9) to the servo object
if (!SD.begin(SD_ChipSelectPin)) // see if the card is present and can be initialized:
Serial.println("SD fail");
return; // don't do anything more if not
tmrpcm.play("start.wav"); // Sound file "Start" will play each time arduino powers up, or is reset
void translateIR()
{ // put your main code here, take action based on IR code rxd
switch(results.value)
case 0x9716BE3F: tmrpcm.play("button1.wav"); Serial.println(" Button #1"); break; // Check IR input for hex 9716BE3F(for button1)to start playback
case 0x3D9AE3F7:
tmrpcm.play("button2.wav");
Serial.println(" Button #2");
// servo sketch
for(pos = 0; pos < 90; pos += 1) // goes 0 deg to 90 deg
{ // in steps of 1 degree
myServo.write(pos); // servo goto posn var.'pos'
Serial.print(" Pos");
Serial.print(pos);
delay(15); //wait 15ms for servo to reach posn
// servo sketch
break; // Check IR input for hex 3D9AE3F7(for button2)to start playback
case 0x6182021B: tmrpcm.play("R2D2.wav"); Serial.println(" Button #3"); break; // Check IR input for hex 6182021B(for button3)to start playback
default: Serial.println(" Nothing ?");
delay(300); // adds a short delay (consider removing later as use of delay() in a sketch has significant drawbacks)
{// put your main code here, to run repeatedly:
if (irrecv.decode(&results)) // Check we have received am IR Signal and run Sub routine ?
translateIR(); // run the Case routine to check on value rxd
irrecv.resume(); // receive next IR value
