SD datalogger...
Hi All,
I came across this sketch, it's just about right for my "Greenhouse data logger" This just reads 3 analogue inputs, these are floating and not connected so the values are similar around an average centre.
  SD card datalogger
  by Tom Igoe
  hacked by Peter Marks to write time stamps
  This example code is in the public domain.
#include <SD.h>
// For the SD Shield Plus
const int chipSelect = 10;
// This is to talk to the real time clock
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68  // This is the I2C address
// Global Variables
int i;
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
  Wire.begin();
  Serial.print("Initializing SD card...\n");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(chipSelect, OUTPUT);
  Serial.print("chipSelect set to output\n");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect))
    Serial.println("Card failed, or not present\n");
    // don't do anything more:
    return;
  Serial.println("card initialized.\n");
  // make a string for assembling the data to log:
  String dataString = getDateDs1307();
  dataString += String(",");
  // read three sensors and append to the string:
  for (int analogPin = 0; analogPin < 3; analogPin++)
    int sensor = analogRead(analogPin);
    dataString += String(sensor);
    if (analogPin < 2)
      dataString += ",";
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("datalog.csv", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile)
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
    Serial.println("error opening datalog.csv");
  delay(1000 * 10);
// Gets the date and time from the ds1307 and return
// result in a format a spreadsheet can parse: 06/10/11 15:10:00
String getDateDs1307()
  // Reset the register pointer
  Wire.beginTransmission(DS1307_I2C_ADDRESS);
  Wire.write(0x00);
  Wire.endTransmission();
  Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
  // A few of these need masks because certain bits are control bits
  second     = bcdToDec(Wire.read() & 0x7F);
  minute     = bcdToDec(Wire.read());
  hour       = bcdToDec(Wire.read() & 0x3F);
  dayOfWeek  = bcdToDec(Wire.read());
  dayOfMonth = bcdToDec(Wire.read());
  month      = bcdToDec(Wire.read());
  year       = bcdToDec(Wire.read());
  String dataString = "";
  dataString += Print2Digit(dayOfMonth);
  dataString += String("/");
  dataString += Print2Digit(bcdToDec(month));
  dataString += String("/"); // Y2k1 bug!
  dataString += Print2Digit(bcdToDec(year));
  dataString += String(" ");
  dataString += Print2Digit(hour);
  dataString += String(":");
  dataString += Print2Digit(minute);
  dataString += Print2Digit(second);
  return dataString;
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
  return ( (val/16*10) + (val%16) );
String Print2Digit(byte Val)
  if (Val < 10)
    dataString = "0";
  dataString += String(Val, DEC);
  return dataString;
I would be using a DS18b20 for temp and would be using a float var, so how would I write this to the SD card? Time is sorted in the sketch, light would be an analoge value so no problem there, as for humidity, not done that before, but read that some sensor are useless and good ones expensive.
Please could some of you advise! any help very welcome.
Regards
Mel.
Here is a snippet to go with three floats from DS18B20. You send data to SD in much the same way as you send it to serial and display. In this case, data goes to serial and LCD once per second and SD once every ten seconds(!).
  Serial.println(InTemp);
  Serial.println(OutTemp);
  Serial.println(DrainTemp);
  lcd.setCursor(49,0);
  lcd.print(InTemp);
  lcd.setCursor(49,1);
  lcd.print (OutTemp);
  lcd.setCursor(49,2);
  lcd.print(DrainTemp);
  lcd.setCursor(49,3);
  lcd.print(diff);
  lcd.print(" ");//suppress trailing fig > 9.99
  lcd.setCursor(17,5);
k=k+1;
  if (k>9 )
           myFile = SD.open(filename, FILE_WRITE);//<<<<<<<<<<<<< OPEN
  myFile.print(hour);
  myFile.print(":");
  myFile.print(minute);
  myFile.print(":");
  myFile.print(second);
  myFile.print(",");
  myFile.print(InTemp);
  myFile.print(",");
  myFile.print(OutTemp);
  myFile.print(",");
  myFile.print(DrainTemp);
  myFile.print(",");
  myFile.print(diff);
  myFile.println();
       myFile.close();//>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>CLOSE
      k=0;
