SD.Fat Library
I am new to this board and not sure if this was the correct place to post this question. I am working with the latest version of SDFat. I am modifying the DataLogger example to take load cell readings as quickly as the HX711 board can send them. I intend to cut the jumper which will place the HX711 in the 80 samples per second mode. I have calculated that 80 samples per second is aprox a sample every 0.0125 seconds. To be on the safe side I have set the scan time of the datalogger to 25 milliseconds. This should take care of any latency in the system. I have been going through the code adding remarks where ever I feel they needed. I have come to a line of code which baffles me.
const uint8_t BASE_NAME_SIZE = sizeof(FILE_BASE_NAME) - 1;
This line is fairly simple to read. The line assigns a value equal to the length of FILE_BASE_NAME Which is an integer equal to '5' and then "1" is subtracted. This leaves BASE_NAME_SIZE at a value of "4".
char fileName[] = FILE_BASE_NAME "00.csv";
This line defines a character array of undeterred size. The filename array is assigned a value of the string constant " FILE_BASE_NAME. This is where my experience fails me. Is the string literal "00.csv" being added to the FILE_BASE_NAME? I don;t see any operator which indicates any kind of addition. It would make sense to add a incrementing end to the file name to allow multiple files to be recorded to the SD Card.
I am going to research the literal string to see if there are any answers there
Thank you for any input you can give me.
Charles O
The FILE_BASE_NAME macro is a string literal:
#define FILE_BASE_NAME "Data"
So this is the equivalent of:
char fileName[] = "Data" "00.csv";
C++ automatically concatenates adjacent string literals, no operator is needed. This is a useful feature in this case.
charles1954:
When you initialize the array, the size is automatically set.
Thank you for the reply. I understood where they were going, but was unaware of that little tidbit about C. My most recent experience with the C language is over 20 years old. I guess its time to dust off some old books and study a little. Again Thank you for your reply, I can carry on now with my programming.
Charles O
