[SD FAT] problem when moving files
hello
I am using GitHub - greiman/SdFat: Arduino FAT16/FAT32 exFAT Library and have problem when moving files.
I write files in the SD root, the renaming to the new desination myfile.ext → destdir/myfile.ext as following
uint32_t CAutomaSD::SD_move(const char* sourceFileName, const char * dirName)
  • uint32_t retVal = ASD_OK;*
  • char destFileName[32]; //TODO: “SENT/8.3” string -->(size 17+\n min?)*
  • snprintf(destFileName, sizeof(destFileName), “%s%s”, dirName, sourceFileName);*
  • if(SD.exists(destFileName))*
  • retVal |= ASD_FILEPREEXIST;*
  • SD.remove(destFileName); //remove from destination dir if present*
  • bool isRenamed = false;*
  • uint8_t tryCnt = 0;*
  • while(!isRenamed)*
  • isRenamed = SD.rename(sourceFileName, destFileName);*
  • tryCnt++;*
  • if(tryCnt == 10)*
  • retVal |= ASD_CANTMOVEFILE;*
  • break;*
  • return retVal;*
as you can see I implemented a retry mechanism just in case. What sometimes happens is that it takes mor than one try for successfully move (rename) a file
In the worst case, and as soon as the number of files in the SD memory gets higher and higher, these epsiodes thends to be higher and higher
My question is about the maturity of this libreary (the rename is a new method compared to the Arduino SD original library) and if renaming files is a safe operation with this library (did anybody tried?)
thanks much in advance for your reply
Try running this test program. It creates files in root and moves them to /DIR.
It runs three passes. The first pass just moves files from root to /DIR. The next two passes remove the existing file from /DIR and then moves the new file. It creates and moves 100 files on each pass.
 * This program tests rename().
#include <SPI.h>
#include <SdFat.h>
// SD chip select pin
const uint8_t chipSelect = SS;
// file system
SdFat sd;
// Serial print stream
ArduinoOutStream cout(Serial);
#define error(s) sd.errorHalt(s)
  File file;
  char dname[20], rname[13];
  while (!Serial) {}  // wait for Leonardo
  cout << F("Insert an empty SD.  Type any character to start.") << endl;
  while (Serial.read() <= 0) {}
  // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
  // breadboards.  use SPI_FULL_SPEED for better performance.
  if (!sd.begin(chipSelect, SPI_HALF_SPEED)) {
    sd.initErrorHalt();
  if (sd.exists("dir")) error("dir exists");
  if (!sd.mkdir("dir")) error("mkdir failed");
  for (int ipass = 0; ipass < 3 ; ipass++) {
    for (int ifile = 0; ifile < 100; ifile++) {
      snprintf(rname, sizeof(rname), "file%d.ext", ifile);
      snprintf(dname, sizeof(dname), "dir/file%d.ext", ifile);
      if (sd.exists(dname)) {
        if (!sd.remove(dname)) error("remove failed");
      if (!file.open(rname, O_CREAT | O_WRITE)) error("open failed");
      file.println(rname);
      file.close();
      if (!sd.rename(rname, dname)) error("rename failed");
  sd.ls(LS_R|LS_SIZE);
  cout << F("Done") << endl;
void loop() {}
It should print the following:
DIR/
FILE0.EXT 11
FILE1.EXT 11
FILE2.EXT 11
FILE3.EXT 11
FILE4.EXT 11
FILE5.EXT 11
FILE6.EXT 11
FILE7.EXT 11
FILE8.EXT 11
FILE9.EXT 11
FILE10.EXT 12
FILE11.EXT 12
FILE12.EXT 12
FILE13.EXT 12
FILE14.EXT 12
FILE15.EXT 12
FILE16.EXT 12
FILE17.EXT 12
FILE18.EXT 12
FILE19.EXT 12
FILE20.EXT 12
FILE21.EXT 12
FILE22.EXT 12
FILE23.EXT 12
FILE24.EXT 12
FILE25.EXT 12
FILE26.EXT 12
FILE27.EXT 12
FILE28.EXT 12
FILE29.EXT 12
FILE30.EXT 12
FILE31.EXT 12
FILE32.EXT 12
FILE33.EXT 12
FILE34.EXT 12
FILE35.EXT 12
FILE36.EXT 12
FILE37.EXT 12
FILE38.EXT 12
FILE39.EXT 12
FILE40.EXT 12
FILE41.EXT 12
FILE42.EXT 12
FILE43.EXT 12
FILE44.EXT 12
FILE45.EXT 12
FILE46.EXT 12
FILE47.EXT 12
FILE48.EXT 12
FILE49.EXT 12
FILE50.EXT 12
FILE51.EXT 12
FILE52.EXT 12
FILE53.EXT 12
FILE54.EXT 12
FILE55.EXT 12
FILE56.EXT 12
FILE57.EXT 12
FILE58.EXT 12
FILE59.EXT 12
FILE60.EXT 12
FILE61.EXT 12
FILE62.EXT 12
FILE63.EXT 12
FILE64.EXT 12
FILE65.EXT 12
FILE66.EXT 12
FILE67.EXT 12
FILE68.EXT 12
FILE69.EXT 12
FILE70.EXT 12
FILE71.EXT 12
FILE72.EXT 12
FILE73.EXT 12
FILE74.EXT 12
FILE75.EXT 12
FILE76.EXT 12
FILE77.EXT 12
FILE78.EXT 12
FILE79.EXT 12
FILE80.EXT 12
FILE81.EXT 12
FILE82.EXT 12
FILE83.EXT 12
FILE84.EXT 12
FILE85.EXT 12
FILE86.EXT 12
FILE87.EXT 12
FILE88.EXT 12
FILE89.EXT 12
FILE90.EXT 12
FILE91.EXT 12
FILE92.EXT 12
FILE93.EXT 12
FILE94.EXT 12
FILE95.EXT 12
FILE96.EXT 12
FILE97.EXT 12
FILE98.EXT 12
FILE99.EXT 12
Done
thanks for you reply first
my code is behaving as the example I think … the only difference is in the file size: I am renaming files of 20-30K and smaller file (<1K). Noticeably the larger files suffer of the issue I reported, while the smaller are renamed ok …
ciao
I am experiment the following now
...\SdFat\SdSpiSAM3X.cpp
define USE_SAM3X_DMAC 0
/** Use extra Bus Matrix arbitration fix if nonzero */
define USE_SAM3X_BUS_MATRIX_FIX 0
/** Time in ms for DMA receive timeout */
define SAM3X_DMA_TIMEOUT (100*3)
/** chip select register number */
define SPI_CHIP_SEL 3
/** DMAC receive channel */
define SPI_DMAC_RX_CH 1
/** DMAC transmit channel */
define SPI_DMAC_TX_CH 0
i.e. NOT using DMA (DMA enable and DMA channels is something that should be decided at system level right? and I do not know if there are other players in my system using DMA channels which may confinct with this
The data is not moved so size does not matter. Only the directory entry moves. You must close the file before you move a file or you may have problems.
Not with Arduino. By default I do use DMA on Due. Some SPI libraries may conflict with DMA use.
Don't "play" with the Due DMA unless you know about the SAM3X DMA channels and bus matrix.
Try disabling DMA. For the current SdFat on GitHub edit SdFatConfig.h. At about line 109 set USE_ARDUINO_SPI_LIBRARY nonzero like this.
#define USE_ARDUINO_SPI_LIBRARY 1
This will use the standard Arduino SPI.h library at slow speed.
Please remove the retry loop from your code. It will never work correctly since you may cause a corrupt file system. If rename fails it is generally because of a hardware problem and this must be fixed. If rename fails because of a bug, retry won't help either.
You need very clean wiring to your SD card since my implementation of DMA SPI on Due runs at 42 MHz.
You could try SdFat-beta, it is a total rewrite. You can disable DMA in the beta by setting SD_SPI_CONFIGURATION to one in SdFatConfig.h.
I increased the file size to 100 KiB (102,400 bytes) and the number of files to 500. I ran this test on a Due with SD_SPI_CONFIGURATION zero to use DMA and one to use the standard Arduino SPI library.
#include <SPI.h>
#include <SdFat.h>
// file system
SdFat sd;
uint8_t block[2048];
  File file;
    sd.initErrorHalt();
    for (int ifile = 0; ifile < 500; ifile++) {
      Serial.print(ipass);
      Serial.write(' ');
      Serial.println(rname);
      for (int k = 0; k < 50; k++) {
        if (sizeof(block) != file.write(block, sizeof(block))) {
          error("write failed");
      file.close();
void loop() {}
I ran the test on SdFat-beta which supports long file names so names are lower case. The test ran without error. Here is the start of the directory listing.
0 dir/
102400 file0.ext
102400 file1.ext
102400 file2.ext
102400 file3.ext
102400 file4.ext
102400 file5.ext
102400 file6.ext
The test prints pass and file name while running:
2 file495.ext
2 file496.ext
2 file497.ext
2 file498.ext
2 file499.ext
This test runs at half speed, 21 MHz for DMA. I also tested it at full speed and it works.
thanks much
