I need help. I'm making an Arduino camera (2nd time) and I can not locate the SD fatfile in the library example section. It's as if it disappeared. I did this project before and the SD fatfile was listed in examples and I had no problem. Now I need to do it again but the fatfile is not there. Where did it go? Is it in another place? Is there something else I can do instead of using SD read/write. I appreciate your advice.
