SD function not working in SdFat lib
Hello Folks
I'm checking the extension of a file using the function below.
Works brilliantly with the standard SD library, but always returns false when using sdFat.
Any hints please? Thanks!
bool isJpg(char* filename) {
  int8_t len = strlen(filename);
  //check file extension for ".jpg"
  if (strstr(strlwr(filename + (len - 4)), ".mid")) {return true;}else{return false;}
On closer inspection it is the entry.name() that isn't working in sdFat.
The library returns "use getName()"
if I replace entry.name with entry.getName() I get compliler error no matching function for call to 'File::getName()'
Here is the code I'm using to get the file name:
void checkForJpg(File dir, int numTabs) {
    File entry =  dir.openNextFile();
      if ( isJpg(entry.name()) ) {} // it's a jpg
Again works fine in SD library
Ok so I figured it out, you can’t just use File with the sdFat, sdFile solved it :slight_smile:
Hi britFrog,
SD card with TFT?
