SD funktionier nicht
Hallo Comunity, ich habe das Problem, dass mein Code, der eigentlich gehen sollte nicht Funktioniert. Das problem hängt irgendwie mit if Abfragen und der SD Karte zusammen
Dieser Code funktioniert:
// Glediator Arduino UNO sketch by Jens Andrée
// 500k bauds with 80 pixels no problem
// sdcard stream for stand-alone operation.
#include <SoftwareSerial.h>
#include <FastLED.h>
#include <SPI.h>
#include <SD.h>
#define NUM_LEDS 144
#define DATA_PIN 3
#define CMD_NEW_DATA 1
File fxdata;
CRGB leds[NUM_LEDS];
SoftwareSerial btSerial(5, 6);
String string = "";
String file ="";
boolean BTconnected = false;
boolean gesendet = false;
boolean wiederholen = false;
byte out[3];
int temp = 0;
int Speed = 50;
  pinMode(8, INPUT_PULLUP);
  pinMode(9, OUTPUT);
  digitalWrite(9, LOW);
  FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS); //se doc for different LED strips
  btSerial.begin(9600);
  for(int y = 0 ; y < NUM_LEDS ; y++)
    leds[y] = CRGB::Black; // set all leds to black during setup
  FastLED.show();
  pinMode(10, OUTPUT); // CS/SS pin as output for SD library to work.
  digitalWrite(10, HIGH); // workaround for sdcard failed error...
  if (!SD.begin(4))
    Serial.println("sdcard initialization failed!");
    return;
  Serial.println("sdcard initialization done.");
  fxdata = SD.open("Boot.dat");
  spiele();
  while (!BTconnected)
    if ( digitalRead(7)==HIGH)  {
      Serial.println("BT verbunden");
      BTconnected = true;
      gesendet = true;
  if (BTconnected and digitalRead(7)==LOW){
    Serial.println("BT getrennt");
  if(gesendet){
  File dataFile = SD.open("list.txt");
  if (dataFile) {
    while (dataFile.available()) {
     btSerial.write(dataFile.read());
    // close the file:
    dataFile.close();
  gesendet = false;
  if(digitalRead(8)==LOW && !wiederholen){
    wiederholen = true;
    digitalWrite(9, HIGH);
    while(digitalRead(8)==LOW){
      delay(10);
  }else{
    if(digitalRead(8)==LOW && wiederholen){
        delay(10);
  if(btSerial.available() > 0) {
    delay(100);
    string = btSerial.readString();
    Serial.println(string);
    if (string.toInt() == 0){
      if (string == "loop"){
        if (!wiederholen){
          wiederholen = true;
      } else if(string == "wuerfel" || string == "zufaellig"){
        Switch();
        fxdata = SD.open(string);
        spiele();
        while (wiederholen){
          spiele();
        btSerial.println("OK");
    }else {
      Serial.println(Speed);
      Speed = 1000 / string.toInt();
void spiele()
  if (fxdata)
      Serial.println("file open ok");
  while (fxdata.available())
     for (int i=0; i <= 143; i++){ //Spalten
      temp = i/12;
      if (temp % 2 != 1){
        fxdata.readBytes(out, 3);
        leds[i][0] = out[0];
        leds[i][1] = out[1];
        leds[i][2] = out[2];
      if (temp % 2 == 1){
        leds[temp*12+11-(i-(temp*12))][0] = out[0];
        leds[temp*12+11-(i-(temp*12))][1] = out[1];
        leds[temp*12+11-(i-(temp*12))][2] = out[2];
    FastLED.show();
    delay(Speed - 25);
  // close the file in order to prevent hanging IO or similar throughout time
  fxdata.close();
void wuerfel(){
  temp = millis();
  while(digitalRead(8) == HIGH){
    if (digitalRead(9) == HIGH){
    } else{
      digitalWrite(9,HIGH);
    delay(100);
    temp = millis();
  delay(50);
  temp = random(1,7);
  while(digitalRead(8) == LOW){
      leds[i] = CRGB::Black;
    if (temp == 1 || temp == 3 || temp == 5){
      leds[65] = CRGB::White;
      leds[66] = CRGB::White;
      leds[77] = CRGB::White;
      leds[78] = CRGB::White;
    if (temp > 1){
      leds[120] = CRGB::White;
      leds[143] = CRGB::White;
      leds[121] = CRGB::White;
      leds[142] = CRGB::White;
      leds[10] = CRGB::White;
      leds[11] = CRGB::White;
      leds[12] = CRGB::White;
      leds[13] = CRGB::White;
      if (temp > 3){
      leds[0] = CRGB::White;
      leds[1] = CRGB::White;
      leds[23] = CRGB::White;
      leds[22] = CRGB::White;
      leds[132] = CRGB::White;
      leds[133] = CRGB::White;
      leds[131] = CRGB::White;
      leds[130] = CRGB::White;
      if (temp == 6){
      leds[70] = CRGB::White;
      leds[71] = CRGB::White;
      leds[72] = CRGB::White;
      leds[73] = CRGB::White;
      leds[61] = CRGB::White;
      leds[60] = CRGB::White;
      leds[82] = CRGB::White;
      leds[83] = CRGB::White;
    FastLED.show();
    delay(50);
    if(temp >= 6){
      temp = 1;
    temp++;
  if(wiederholen){
void zufall(){
  temp = 1;
  while(temp){
    leds[random(0, 144)].setRGB(random(0, 255), random(0, 255), random(0, 255));
    FastLED.show();
      delay(100);
      loop();
void Switch(){
  if (string == "wuerfel"){
    wuerfel();
//  if (string == "zufaellig"){
//    zufall();
wenn ich aber die Kommentare unten entferne sodass der Code aktiv ist, funktioniert am anfang das Boot.dat, aber wenn ich über Bluetooth dateien starte funktioniert das nicht.
Hi
      delay(100);
      loop();
Was denkst Du, machst Du da? (steht wenige Zeilen über den drei ausgeremmten Zeilen)
MfG
Es wäre schon toll, wenn du nicht nur schreibst, es geht nicht.
Sondern mal genauer beschreibst, was du erwartest und was genau nicht funktioniert.
Da dem kopierten Sketch jegliche Kommentare fehlen, damit ist es für schwer den Sketch zu analysieren.
Wenn du an geeigneter Stelle ein paar Serial.print einbringst, kannst du sicher einiges heraus finden.
loop() rekursiv aufzurufen (ich gehe davon aus, der Codeschnipsel steht im Loop, mehr Info ist ja nicht vorhanden) ist mit sicherheit der Tod des Programms.
Du solltest mal mit dem Studium einiger Grundlagen beginnen.
Gruß Tommy
Schildkroete1:
... dass mein Code, der eigentlich gehen sollte, nicht Funktioniert.
Das Problem habe ich leider auch oft.
Der Arduino ist bei der Interpretation des Codes anderer Ansicht als ich. :confused:
Leider behält bei solchen Diskussionen am Ende eigentlich immer der Arduino recht. >:(
Kannst du denn die SD-Karte überhaupt ansprechen?
Lade doch einfach mal ein Beispiel aus der SD lib, ob die Karte erkannt wird, damit du Hardwarefehler ausschliessen kannst.
