SD.h Disables OLED Display
I am trying to use an SSD1306 128x64 OLED display with an SD card breakout board; both are setup to use the SPI interface. The display works fine until I include the SD.h file in the code; nothing else is done with the SD card module, just including the SD.h file is all it takes to disable the OLED display (see code below). If I don't include the SD.h file, the display clears and shows the "Initializing SD card..." message.
Any suggestions why this is happening?
BTW: I'm using an UNO.
SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module.
Pin 10 used here for consistency with other Arduino examples
created 28 Mar 2011
by Limor Fried
modified 9 Apr 2012
by Tom Igoe
// include the SD library:
#include <SPI.h>
#include <SD.h>
//#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <splash.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define CHAR_WIDTH 6
#define CHAR_HEIGHT 8
#define OLED_DC 6
#define OLED_CS 7
#define OLED_RESET 8
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT,
&SPI, OLED_DC, OLED_RESET, OLED_CS);
// set up variables using the SD utility library functions:
//Sd2Card card;
//SdVolume volume;
//SdFile root;
const int chipSelect = 10;
display.begin(SSD1306_SWITCHCAPVCC);
display.cp437(true); // Use full 256 char 'Code Page 437' font
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.display();
delay(2000);
display.println("Initializing SD card...");
display.display();
// REAMINING CODE IS COMMENTED OUT
/* if (!card.init(SPI_HALF_SPEED, chipSelect))
display.println("initialization failed. Things to check:");
display.println("* is a card inserted?");
display.println("* is your wiring correct?");
display.println("* did you change the chipSelect pin to match your shield or module?");
while (1);
display.println("Wiring is correct and a card is present.");
display.display();
// print the type of card
/* display.println();
display.print("Card type: ");
switch (card.type())
case SD_CARD_TYPE_SD1:
display.println("SD1");
case SD_CARD_TYPE_SD2:
display.println("SD2");
case SD_CARD_TYPE_SDHC:
display.println("SDHC");
default:
display.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card))
display.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
while (1);
display.print("Clusters: ");
display.println(volume.clusterCount());
display.print("Blocks x Cluster: ");
display.println(volume.blocksPerCluster());
display.print("Total Blocks: ");
display.println(volume.blocksPerCluster() * volume.clusterCount());
display.println();
// print the type and size of the first FAT-type volume
uint32_t volumesize;
display.print("Volume type is: FAT");
display.println(volume.fatType(), DEC);
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
volumesize /= 2; // SD card blocks are always 512 bytes (2 blocks are 1KB)
display.print("Volume size (Kb): ");
display.println(volumesize);
display.print("Volume size (Mb): ");
volumesize /= 1024;
display.print("Volume size (Gb): ");
Serial.println((float)volumesize / 1024.0);
display.println("\nFiles found on the card (name, date and size in bytes): ");
root.openRoot(volume);
// list all files in the card with date and size
root.ls(LS_R | LS_DATE | LS_SIZE);*/
void loop(void) {
What happens if you include the file, but don't attach the SD module?
Nothing different...just including the SD.h file causes this problem, whether the SD module is connected or not.
Including the SD library is using a considerable amount of dynamic memory, my guess would be the OLED needs more memory than you have left.
david_2018:
Including the SD.h library: 52% Program Memory; 54% Dynamic Memory
Without the SD.h library: 39% Program Memory; 16% Dynamic Memory
I set up the same program on a MEGA 2560...IT WORKS!
I'm going to try setting it up on a NANO Every, the original target processor for this project; hopefully it will work.
Wow, that's bizarre. Yet fits in with my experiences: sometimes I compile a program and it fails, then I recompile without changing anything and it succeeds...sometimes it takes more than one recompile. That shouldn't happen.
The combination of the SD card module and the SSD1306 works on the NANO Every and the MEGA 2560, but NOT on the UNO; I guess the UNO just lacks something.
MK1888:
I've run into that a few times myself, the IDE just says it can't compile the sketch; then I exit the IDE, restart it, and the sketch compiles just fine.
