Is possible rename a file on SD using standard libraries in arduino SDK?
Many thank
realmeteo:
Many thank
That depends on your definition of "standard libraries". Installed when you install the IDE? Or installed when you use the menu item to install a new library? SDFat includes the ability to rename a file.
Excuse me for low details, Iām speaking about Arduino ā Examples ā SD
ā¦
#include <SPI.h>
#include <SD.h>
You have the source code for the SD library. You can easily see that it does not provide a rename() method.
