SD initializing get failed on running it second time
After uploading cardinfo code from example on uno
  1. SD card fails to initialize first time
    then
  2. I remove Vcc & plug it again,close the serial moniter window & on reopening it, SD card gets initialized ,
then
3) After closing serial moniter window & opening it again , SD card again fails to initialize
I have to repeat step 2 to make it work again
In the pic is the sd card sheild I use
I replaced CS pin as 10
