SD library and DS1307 library conflict
I'm tryng to create a Dallas iButton ( Ds1990 ) but I can't becouse I'm using SD library to read from SD Card the iButton address and DS1307 to display date and time on LCD 20x4
If I compile the sketch with DS1307 Commented the sketch works loadind file inside the SD Card
If I enable DS1307 the file inside SD Card is not readed ( it is found but the problem is
 if (config_file)
return false when DS1307 is enable )
Do you know something about this problem ? On google I read that there is some problem
There is. You didn't post a schematic. You didn't post your code.
this is the schematics
Later I’ll post the code
ticino 16x2 ds3231 SBROGLIATO .pdf (62.5 KB)
This is the code.
iButton_v10.ino (11 KB)
this is the pcd just assembled
Which could be the solution ???
googling and searching I found that
The solution to this problem, is that you have to let digital Pin 10 as output (for the SD library to work) and put out a logic HIGH by adding “digitalWrite(10,HIGH);”. For Arduino Mega you have to do exactly the same ignore pin 53 completely though the comment asks you to change it to 53.
could be this the solution ??
Did it work? If not, it isn't. It it did, it was.
Ahahahahahhahaha later I'll try.
PaulS it this what you thinked before ??
Not working…
any ideas ?
PaulS I belive in you ! What do you suggest ??
Thank you so much
Daniele
