I'm using an Arduino Uno. I need to determine the file size of an mp3 file, in order to determine the length of the track. I have the math to determine the length of track with the file size. I'm using the SD library.
The issue I have, is that size() returns the accurate size of text files, but not mp3 files.
myFile = SD.open(file);
unsigned long siz = myFile.size();
Serial.print("File size is: "); Serial.println(siz);
String prefix = "/tunes/";
String suffix = ".mp3";
String file = prefix + rand_indice + suffix;
Serial.print("track is: "); Serial.println(file);
siz = 0;
Serial.print("Track size is: "); Serial.println(siz);
myFile.close();
The Serial out put is:
File size is: 376
track is: /tunes/5.mp3
Track size is: 16796674
The file size from a command prompt for the mp3 is: 350666
I can't help you with your question... My C++ is too rusty.
Are you sure you're actually reading the correct file? Can you play the file using the same file-opening syntax. Or, Maybe you can read the first-several bytes and display them on the serial monitor, then compare that to what you see on a computer (a hex editor would make that easy). Or, read the file one byte at a time and count-up the bytes.
By "length", do you mean playing time? That can be tricky with MP3. You can approximate it if you know the file-size and bitrate, but with variable bitrate MP3s you need to know the average bitrate for the particular file.
To get accurate playing time, I think you have to analyze the MP3 frame-by-frame. I've seen an example of that once, but I can't find it right now.
There may also be a playing-time "tag", but they are not always correct.
Learn about standard string handling in the C/C++ programming language and nullterminated C-style sttrings!
I think your problems are caused because you are using Arduino "String" objects with the SD library, which takes null-terminated strings as file name parameters in function calls and NOT "String! objects.
