Using the read wire example my file will not open if the name is "111-111-111.txt" but if I rename it to "Test.txt" it will open.
From the SD library reference page:
https://www.arduino.cc/en/Reference/SD
It uses short 8.3 names for files.
This is a confusing way of saying that the first part of the file name has a maximum length of 8 characters and the file extension has a maximum length of 3 characters.
The first part of your “111-111-111.txt” filename has 11 characters, which is not allowed. The first part of your “Test.txt” filename has 4 characters, which is fine.
Well that is unfortunate. Is there a similar library that I could use to allow a file name like my example. There is no way I could shorten the name it's just the matter of the business.
I believe the library "SdFat" by Bill Greiman supports long file names. You can install it via the Arduino Library Manager. Just search for "sdfat".
This topic was automatically closed after 120 days. New replies are no longer allowed.
