I am using a Data Logger Feather from Adafruit mounted on a M0 Feather which uses the SAMD chip.
The card being used is a SDHC and formatted for FAT32.
Card Info code on SD Library works fine. But when I try SDFat library it fails with the following message .
Cannot figure out why ?
Do you think it might help if you posted your code ?
The easier you make it to read and copy your code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
If you get errors when compiling please copy them from the IDE using the "Copy error messages" button and paste the clipboard here in code tags
This is the code ... available as an Example in the latest SDFat library. I have only changed the SD_CS_PIN value to 10.
* This program attempts to initialize an SD card and analyze its structure.
#include "SdFat.h"
#include "sdios.h"
Set DISABLE_CS_PIN to disable a second SPI device.
For example, with the Ethernet shield, set DISABLE_CS_PIN
to 10 to disable the Ethernet controller.
const int8_t DISABLE_CS_PIN =4;
Change the value of SD_CS_PIN if you are using SPI
and your hardware does not use the default value, SS.
Common values are:
Arduino Ethernet shield: pin 4
Sparkfun SD shield: pin 8
Adafruit SD shields and modules: pin 10
// SDCARD_SS_PIN is defined for the built-in SD on some boards.
#ifndef SDCARD_SS_PIN
const uint8_t SD_CS_PIN = 10;
#else // SDCARD_SS_PIN
#endif // SDCARD_SS_PIN
// Try to select the best SD card configuration.
#if HAS_SDIO_CLASS
#define SD_CONFIG SdioConfig(FIFO_SDIO)
#elif ENABLE_DEDICATED_SPI
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, DEDICATED_SPI, SD_SCK_MHZ(16))
#else // HAS_SDIO_CLASS
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, SHARED_SPI, SD_SCK_MHZ(16))
#endif // HAS_SDIO_CLASS
SdFs sd;
cid_t m_cid;
csd_t m_csd;
uint32_t m_eraseSize;
uint32_t m_ocr;
static ArduinoOutStream cout(Serial);
bool cidDmp() {
cout << F("\nManufacturer ID: ");
cout << uppercase << showbase << hex << int(m_cid.mid) << dec << endl;
cout << F("OEM ID: ") << m_cid.oid[0] << m_cid.oid[1] << endl;
cout << F("Product: ");
for (uint8_t i = 0; i < 5; i++) {
cout << m_cid.pnm[i];
cout << F("\nVersion: ");
cout << int(m_cid.prv_n) << '.' << int(m_cid.prv_m) << endl;
cout << F("Serial number: ") << hex << m_cid.psn << dec << endl;
cout << F("Manufacturing date: ");
cout << int(m_cid.mdt_month) << '/';
cout << (2000 + m_cid.mdt_year_low + 10 * m_cid.mdt_year_high) << endl;
cout << endl;
return true;
void clearSerialInput() {
uint32_t m = micros();
do {
if (Serial.read() >= 0) {
m = micros();
} while (micros() - m < 10000);
bool csdDmp() {
bool eraseSingleBlock;
if (m_csd.v1.csd_ver == 0) {
eraseSingleBlock = m_csd.v1.erase_blk_en;
m_eraseSize = (m_csd.v1.sector_size_high << 1) | m_csd.v1.sector_size_low;
} else if (m_csd.v2.csd_ver == 1) {
eraseSingleBlock = m_csd.v2.erase_blk_en;
m_eraseSize = (m_csd.v2.sector_size_high << 1) | m_csd.v2.sector_size_low;
cout << F("m_csd version error\n");
return false;
m_eraseSize++;
cout << F("cardSize: ") << 0.000512 * sdCardCapacity(&m_csd);
cout << F(" MB (MB = 1,000,000 bytes)\n");
cout << F("flashEraseSize: ") << int(m_eraseSize) << F(" blocks\n");
cout << F("eraseSingleBlock: ");
if (eraseSingleBlock) {
cout << F("true\n");
cout << F("false\n");
return true;
void errorPrint() {
if (sd.sdErrorCode()) {
cout << F("SD errorCode: ") << hex << showbase;
printSdErrorSymbol(&Serial, sd.sdErrorCode());
cout << F(" = ") << int(sd.sdErrorCode()) << endl;
cout << F("SD errorData = ") << int(sd.sdErrorData()) << endl;
bool mbrDmp() {
MbrSector_t mbr;
bool valid = true;
if (!sd.card()->readSector(0, (uint8_t*)&mbr)) {
cout << F("\nread MBR failed.\n");
errorPrint();
return false;
cout << F("\nSD Partition Table\n");
cout << F("part,boot,bgnCHS[3],type,endCHS[3],start,length\n");
for (uint8_t ip = 1; ip < 5; ip++) {
MbrPart_t *pt = &mbr.part[ip - 1];
if ((pt->boot != 0 && pt->boot != 0X80) ||
getLe32(pt->relativeSectors) > sdCardCapacity(&m_csd)) {
valid = false;
cout << int(ip) << ',' << uppercase << showbase << hex;
cout << int(pt->boot) << ',';
for (int i = 0; i < 3; i++ ) {
cout << int(pt->beginCHS[i]) << ',';
cout << int(pt->type) << ',';
cout << int(pt->endCHS[i]) << ',';
cout << dec << getLe32(pt->relativeSectors) << ',';
cout << getLe32(pt->totalSectors) << endl;
if (!valid) {
cout << F("\nMBR not valid, assuming Super Floppy format.\n");
return true;
void dmpVol() {
cout << F("\nScanning FAT, please wait.\n");
uint32_t freeClusterCount = sd.freeClusterCount();
if (sd.fatType() <= 32) {
cout << F("\nVolume is FAT") << int(sd.fatType()) << endl;
cout << F("\nVolume is exFAT\n");
cout << F("sectorsPerCluster: ") << sd.sectorsPerCluster() << endl;
cout << F("clusterCount: ") << sd.clusterCount() << endl;
cout << F("freeClusterCount: ") << freeClusterCount << endl;
cout << F("fatStartSector: ") << sd.fatStartSector() << endl;
cout << F("dataStartSector: ") << sd.dataStartSector() << endl;
if (sd.dataStartSector() % m_eraseSize) {
cout << F("Data area is not aligned on flash erase boundary!\n");
cout << F("Download and use formatter from www.sdcard.org!\n");
void printCardType() {
cout << F("\nCard type: ");
switch (sd.card()->type()) {
case SD_CARD_TYPE_SD1:
cout << F("SD1\n");
case SD_CARD_TYPE_SD2:
cout << F("SD2\n");
case SD_CARD_TYPE_SDHC:
if (sdCardCapacity(&m_csd) < 70000000) {
cout << F("SDHC\n");
cout << F("SDXC\n");
default:
cout << F("Unknown\n");
void printConfig(SdSpiConfig config) {
if (DISABLE_CS_PIN < 0) {
cout << F(
"\nAssuming the SD is the only SPI device.\n"
"Edit DISABLE_CS_PIN to disable an SPI device.\n");
cout << F("\nDisabling SPI device on pin ");
cout << int(DISABLE_CS_PIN) << endl;
pinMode(DISABLE_CS_PIN, OUTPUT);
digitalWrite(DISABLE_CS_PIN, HIGH);
cout << F("\nAssuming the SD chip select pin is: ") << int(config.csPin);
cout << F("\nEdit SD_CS_PIN to change the SD chip select pin.\n");
void printConfig(SdioConfig config) {
(void)config;
cout << F("Assuming an SDIO interface.\n");
// Wait for USB Serial
while (!Serial) {
SysCall::yield();
cout << F("SdFat version: ") << SD_FAT_VERSION_STR << endl;
printConfig(SD_CONFIG);
// Read any existing Serial data.
clearSerialInput();
// F stores strings in flash to save RAM
cout << F("\ntype any character to start\n");
while (!Serial.available()) {
SysCall::yield();
uint32_t t = millis();
if (!sd.cardBegin(SD_CONFIG)) {
cout << F(
"\nSD initialization failed.\n"
"Do not reformat the card!\n"
"Is the card correctly inserted?\n"
"Is there a wiring/soldering problem?\n");
if (isSpi(SD_CONFIG)) {
cout << F(
"Is SD_CS_PIN set to the correct value?\n"
"Does another SPI device need to be disabled?\n"
errorPrint();
return;
t = millis() - t;
cout << F("init time: ") << t << " ms" << endl;
if (!sd.card()->readCID(&m_cid) ||
!sd.card()->readCSD(&m_csd) ||
!sd.card()->readOCR(&m_ocr)) {
cout << F("readInfo failed\n");
errorPrint();
return;
printCardType();
cidDmp();
csdDmp();
cout << F("\nOCR: ") << uppercase << showbase;
cout << hex << m_ocr << dec << endl;
if (!mbrDmp()) {
return;
if (!sd.volumeBegin()) {
cout << F("\nvolumeBegin failed. Is the card formatted?\n");
errorPrint();
return;
dmpVol();
Ok just to cross check tried with a Uno and SD Shield from Adafruit with the SDFat library. It worked fine the first attempt.
So looks like this particular library is aimed at the AVR chips and not the Cortex M0 chips which the Adafrfuit M0 feather uses.
system
Closed
5
