Whenever I try to run the example code from adafruit to display a picture to the screen from the SD card it fails. The SD card programming is the same as other sketches that do open the SD correctly. Also, whenever I run the adafruit code the SD card will not work for other sketches until it is unplugged and then replugged. Attached are the sketches.
SD_logger.ino (467 Bytes)
spitftbitmap.ino (6.5 KB)
