Sure, here's the entire Program:
Channels:
Throttle = 0
Aileron = 1
Elevator = 2
Roll = 3
Armswitch = 4
Pins:
SD Karte
CS = 10
SCK = 13
MOSI = 11
MISO = 12
Gyro
SCL = A5
SDA = A4
Baro
SCL = A5
SDA = A4
XF Nano RX
SBUS = 0
Servo Comm
Softwareserial TX = 9
-Unused- Softwareserial RX = 10
#include <SPI.h>
#include "Wire.h"
#include "SoftwareSerial.h"
#include <MPU6050_light.h>
#include <Adafruit_BMP280.h>
#include <SD.h>
#include "sbus.h"
//------------------------------SERIAL---------------------------------------------
MPU6050 mpu(Wire);
SoftwareSerial dataBus(10, 9);
bfs::SbusRx sbus_rx(&Serial);
bfs::SbusData data;
//------------------------------CONTROL--------------------------------------------
float neutral_settings[6] = {1001, 1001, 1440, 1450, 1450, 1400};
float servoSetpoints[6] = {neutral_settings[0], neutral_settings[1], neutral_settings[2], neutral_settings[3], neutral_settings[4], neutral_settings[5]};
float servoDirections[4][6] = { {1, 1, 0, 0, 0, 0}, //thrust
{0, 0, 0, 0, 1, -1}, //roll
{0, 0, -1, 1, 0, 0}, //nick
{0, 0, 1, 1, 1, 1}}; //yaw WITHOUT motors
//{-1, 1, 1, 1, 1, 1}}; //yaw WITH motors
int motors_idle = 1063;
int sbus_min = 173;
int sbus_max = 1810;
bool armswitch_latch = false;
bool arming_failed = true;
//------------------------------PID/RATES------------------------------------------
float gyroX, gyroY, gyroZ;
float lastGyroX, lastGyroY, lastGyroZ;
float pid_corrections[4] {0, 0, 0, 0}; // thrust, roll, nick, yaw
float p[4] = {0, 2, 3, 3};
float d[4] = {0, 4, 6, 6};
float i[4] = {0, 0, 0, 0};
int roll_deg = 180; // roll degrees at full stick reflection
int nick_deg = 180; // roll degrees at full stick reflection
int yaw_deg = 180; // roll degrees at full stick reflection
//------------------------------SD CARD--------------------------------------------
#define chipSelect 10 //CS for SD Card
long driveNum;
String filename;
File blackbox_file;
bool file_write = false;
bool last_file_write_state = false;
//-------------------SERIAL--------------------
sbus_rx.Begin();
dataBus.begin(115200);
Wire.begin();
SPI.begin();
//---------------------MPU---------------------
byte status = mpu.begin();
while(status!=0){} // stop everything if unable to connect to MPU6050
mpu.calcOffsets(true, true); // gyro and accelero
//---------------------SD----------------------
byte sd_status = SD.begin(chipSelect);
if (!sd_status){
// don't do anything more:
while (1){}
File root; //get drive Number
root = SD.open("/");
driveNum = highestNumber(root, &filename);
root.close();
if (sbus_rx.Read()) {
data = sbus_rx.data();
mpu.update();
gyroX = mpu.getGyroX() + minmax(map(data.ch[3], sbus_min, sbus_max, -yaw_deg, yaw_deg), -yaw_deg, yaw_deg);
gyroY = mpu.getGyroY() - minmax(map(data.ch[2], sbus_min, sbus_max, -nick_deg, nick_deg), -nick_deg, nick_deg);
gyroZ = mpu.getGyroZ() + minmax(map(data.ch[1], sbus_min, sbus_max, -roll_deg, roll_deg), -roll_deg, roll_deg);
pid_controller();
calculateServoVals();
sendPackage();
void pid_controller(){
pid_corrections[3] = -gyroX * p[1]; // P-val
pid_corrections[2] = -gyroY * p[2];
pid_corrections[1] = gyroZ * p[3];
pid_corrections[3] += (lastGyroX - gyroX) * d[1]; // D-val
pid_corrections[2] += (lastGyroY - gyroY) * d[2];
pid_corrections[1] += -(lastGyroZ - gyroZ) * d[3];
lastGyroX = gyroX;
lastGyroY = gyroY;
lastGyroZ = gyroZ;
void sendPackage(){
dataBus.print("%0,"); // MOTOR
dataBus.print((int)servoSetpoints[0]);
dataBus.print(';');
dataBus.print("%1,"); // MOTOR
dataBus.print((int)servoSetpoints[1]);
dataBus.print(';');
dataBus.print("%2,"); // SERVO
dataBus.print((int)servoSetpoints[2]);
dataBus.print(';');
dataBus.print("%3,"); // SERVO
dataBus.print((int)servoSetpoints[3]);
dataBus.print(';');
dataBus.print("%4,"); // SERVO
dataBus.print((int)servoSetpoints[4]);
dataBus.print(';');
dataBus.print("%5,"); // SERVO
dataBus.print((int)servoSetpoints[5]);
dataBus.print(';');
void calculateServoVals(){
for(int i = 0; i < 6; i++){
servoSetpoints[i] = neutral_settings[i];
servoSetpoints[0] = minmax(map(data.ch[0], sbus_min, sbus_max, 1001, 2000), 1001, 2000); // simple throttle set
servoSetpoints[1] = minmax(map(data.ch[0], sbus_min, sbus_max, 1001, 2000), 1001, 2000);
// add every control to the mix
for(int f = 1; f < 4; f++){ // goes through AER of the TAER control axis
for(int i = 2; i < 6; i++){ // goes through every Servo
servoSetpoints[i] = minmax(servoSetpoints[i] + (pid_corrections[f] * servoDirections[f][i]), 1000, 2000);
arm_handling(); // DO NOT REMOVE, SAFETY HAZARD
void arm_handling(){
file_write = true;
if (data.ch[4] < 500) { // Armswitch in off position
file_write = false;
for (int i = 0; i < 6; i++) {
else if (data.ch[4] > 500 && data.ch[4] < 1500) { // Armswitch in middle position
file_write = false;
servoSetpoints[0] = neutral_settings[0];
servoSetpoints[1] = neutral_settings[1];
else if (data.ch[4] > 1500){ // Armswitch in arm position
servoSetpoints[0] = minmax(servoSetpoints[0], motors_idle, 2000);
servoSetpoints[1] = minmax(servoSetpoints[1], motors_idle, 2000);
if(data.ch[4] > 1500 && armswitch_latch == false){ // Armswitch moved ti Arm position
if(data.ch[0] <= 200){ // If Thrust almost 0, arm the Fucker
armswitch_latch = true;
arming_failed = false;
if(data.ch[0] > 200){ // If Thrust over almost 0, DO NOT arm the fucker, only arm if the Armswitch is moved into Middle position and back
file_write = false;
if(data.ch[4] < 1500 && armswitch_latch == true){ // If Arm mode is active and Armswitch is moved back, disarm
file_write = false;
if(armswitch_latch == false || arming_failed == true){ // If Disarmed or Armed with Thrust up, set Thrust outputs to 0
file_write = false;
write_blackbox(file_write);
void write_blackbox(bool active){
if(active && last_file_write_state){
blackbox_file.println("Appended to the EOF");
else if (!active && last_file_write_state) {
blackbox_file.close();
else if (active && !last_file_write_state) {
blackbox_file = SD.open(filename, FILE_WRITE);
//blackbox_file.seek(EOF);
last_file_write_state = true;
float minmax(float val, float min, float max){
if(val < min){
val = min;
if(val > max){
val = max;
return val;
long highestNumber(File dir, String* filenameaddress){
long highestNum = 0;
while (true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
String filename = String(entry.name());
String extractedNum = String(filename[0]);
extractedNum += String(filename[1]);
extractedNum += String(filename[2]);
extractedNum += String(filename[3]);
extractedNum += String(filename[4]);
int number = extractedNum.toInt();
if(number > highestNum){
highestNum = number;
highestNum += 1;
*filenameaddress = "/";
if (highestNum < 10) {
*filenameaddress += "0000";
*filenameaddress += String(highestNum);
*filenameaddress += ".txt";
else if (highestNum < 100) {
*filenameaddress += "000";
else if (highestNum < 1000) {
*filenameaddress += "00";
else if (highestNum < 10000) {
*filenameaddress += "0";
else if (highestNum < 100000) {
return highestNum;
