Sd_Open() function doesnt work properly but when im dislocate the function to near while(1) loop it works and i can see my html code on the internet. (Btw im trying to get speed of a motor and visulize on a grafiphical interface in internet.) Can u guys help me pls.
#include <Ethernet.h>
#include <SPI.h>
#include <SD.h>
File myFile;
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x4A, 0xE0 };
EthernetServer server(80);
boolean receiving = false; //keep track if receiving data
int freq = 0;
int pin;
// Pins
#define ENCA 3
#define ENCB 2
#define PWM 5
#define IN1 9
#define IN2 6
EthernetClient client;
pinMode(53, OUTPUT);
Ethernet.init(10);
pinMode(ENCA, INPUT);
pinMode(ENCB, INPUT);
pinMode(PWM, OUTPUT);
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
Serial.println(F("Initializing SD card..."));
if (!SD.begin(4)) {
Serial.println(F("Initialization failed!"));
return;
Serial.println(F("Initialization OK"));
if (!SD.exists("dhtajax.htm")) {
Serial.println(F("dhtajax.htm not found!"));
return;
Serial.println(F("dhtajax.htm found"));
if (!Ethernet.begin(mac)) //connect with DHCP
Serial.println("Could not Configure Ethernet with DHCP.");
return;
} else Serial.println("Ethernet Configured!");
server.begin();
Serial.print(F("Server Started...\nLocal IP: "));
Serial.println(Ethernet.localIP());
myFile = SD.open("deneme.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println("testing 1, 2, 3.");
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening deneme.txt");
myFile = SD.open("deneme.txt");
if (myFile) {
Serial.println("deneme.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
myFile.close();
open_me();
open_me();
open_me();
open_me();
while (1) {
delay(100);
String HTTP_req;
client = server.available();
if (client) {
//HTTP request ends with a blank line
boolean currentLineIsBlank = true;
boolean sentHeader = false;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (receiving && c == ' ') receiving = false;//Done receiving
if (c == '?') receiving = true;
//found arguments
if (receiving) //looking at GET requests
//LED command is specified with an L
if (c == 'V') {
Serial.print("Velocity =");
pin = client.parseInt();
Serial.println(pin);
//speaker command is specified with an S
else if (c == 'D') {
Serial.print("Kd = ");
freq = client.parseInt();
Serial.println(freq);
HTTP_req += c;
if (c == '\n' && currentLineIsBlank) {
//client.println("HTTP/1.1 200 OK\n\rContent-Type: text/html\n\r\n\r");
if (HTTP_req.indexOf("readDHT11") > -1) {
client.println("Velocity : ");
delay(2000);
//client.write("<h2 align=center><font size=7><b>The height of the body </b></font></h2>");
/*myFile = SD.open("dhtajax.htm", O_READ);
Serial.println(myFile);
if (1) {
client.write(myFile.read());
//Serial.write(myFile.read());
Serial.println("sd girdi");
myFile.close();
if (1) {
myFile.close();
//HTTP_req = "";
if (c == '\n') currentLineIsBlank = true;
else if (c != '\r') currentLineIsBlank = false;
delay(10);
client.stop();
void open_me(){
if (myFile){
myFile.close();
