SD.open issues
Hi all,
I'm trying to feed a variable in as a file name for SD.open() with no luck. If I use a defined character string it works fine.
myFile = SD.open("sample_0000.txt", FILE_WRITE);
I'm generating my file names using Strings and I know that SD.open() doesn't support Strings. I've found several posts on this forum along these lines but was unable to make a solution work.
I've tried the following methods of conversion with no success:
// currentFileName is a String defined earlier and in a fixed 11.3 format
 char fileName_converted[16];
  currentFileName.toCharArray(fileName_converted, 16);
  myFile = SD.open(fileName_converted, FILE_WRITE);
  if (myFile){
    Serial.println("File open was successful.");
    myFile.println("test");
    myFile.close();
and
  myFile = SD.open(currentFileName.c_str(), FILE_WRITE);
  if (myFile){
    myFile.close();
Can anyone help me figure out why I can't seem to convert this String to a proper character array that SD.open() will like?
I believe SD.open() has an overload for String, so using a String as an argument should work.
Basic diagnostic practise says that you should print out your converted string to serial to see what it looks like.
It would be more useful to post a minimal compilable sketch that exhibits the issue, rather than a bunch of fragments. In particular we would need to see how currentFileName is constructed and used.
Hi thanks for the feedback! I actually took a bajillion print statements out of the above code to make it easier to read - I can find no differences between the data in the examples even when I go through the character array a character at a time and print it. Below is the same code but included in a format that I think you can copy, paste, and run. Beyond the copy and paste, just call the function generateNewFile()in your setup function and it should work fine.
The board is an Adafruit Feather M0 Adalogger, since I failed to mention that above.
In all examples below, seeing the text "File open was successful." indicates success.
This is the standard code you'll find in most examples and it works fine. Note the hardcoded file name.
#include <SPI.h>
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
const int chipSelect = 4;
int fileNum = 0;
String fileName = "sample_";
String extension = ".txt";
bool outOfFiles = false;
void generateNewFile()
  String currentFileName = "";
  String stringNum = "";
  File myFile;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("\nInitializing SD card...");
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card inserted?");
    Serial.println("* is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    while (1);
    //replace while with interrupt code to gracefully handle the error
    Serial.println("Wiring is correct and a card is present.");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    while (1);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    while (1);
  if (fileNum < 10){
    stringNum = "000" + String(fileNum, DEC);
  else if (fileNum < 100){
    stringNum = "00" + String(fileNum, DEC);
  else if (fileNum < 1000){
    stringNum = "0" + String(fileNum, DEC);
  else {
    stringNum = String(fileNum, DEC);
  currentFileName = fileName + stringNum + extension;
  Serial.println(currentFileName);
  fileNum++;
  if (fileNum > 9999){
    outOfFiles = true;
  myFile = SD.open("testfile.txt", FILE_WRITE);
  if (myFile){
    myFile.close();
  Serial.println("File operation complete.");
So with the above code we can demonstrate that everything works and things are talking as they should. The next examples illustrate my problem of converting the String I want to use (currentFileName) to a form SD.open() will accept. None of the following methods generate a file on the micro SD card (they are in following posts, since everything together was too long for a single post).
This example attempts to convert the String currentFileName to a character array.
#include <SPI.h>
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
int fileNum = 0;
  File myFile;
  while (!Serial) {
    while (1);
    while (1);
  if (!SD.begin(4)) {
    while (1);
  if (fileNum < 10){
  else {
  fileNum++;
    outOfFiles = true;
  Serial.println(fileName_converted);
  for (int i=0; i<16; i++){
    Serial.print(fileName_converted[i]);
  Serial.println(".");
  if (myFile){
    myFile.close();
This example attempts to use another method of Stringto do the conversion for me:
#include <SPI.h>
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
int fileNum = 0;
  File myFile;
  while (!Serial) {
    while (1);
    while (1);
  if (!SD.begin(4)) {
    while (1);
  if (fileNum < 10){
  else {
  fileNum++;
    outOfFiles = true;
  Serial.println(currentFileName.c_str());
  if (myFile){
    myFile.close();
Finally, here is an example of just using the String currentFileNamewith no conversion.
#include <SPI.h>
#include <SD.h>
Sd2Card card;
SdVolume volume;
SdFile root;
int fileNum = 0;
  File myFile;
  while (!Serial) {
    while (1);
    while (1);
  if (!SD.begin(4)) {
    while (1);
  if (fileNum < 10){
  else {
  fileNum++;
    outOfFiles = true;
  myFile = SD.open(currentFileName, FILE_WRITE);
  if (myFile){
    myFile.close();
Many thanks in advance for your patience!
SD.h does not support long file names. Are the constructed file names larger than 8.3?
"testfile.txt" meets that criteria.
You may want want to change the library to SdFat.h which supports long file names.
They are indeed bigger than 8.3. I shortened them and now I've got working files. Thanks a ton!
schtoom:
Which effectively demonstrates why posting snippets of code is often useless. In your first post you stated:
schtoom:
You clearly hadn't tested this.
