I need to convert the sketch from the SD library to the SDFat library. Do not know how (((
Help me please!
#include <SPI.h>
#include <SD.h>
#include <UTFT.h>
UTFT myGLCD(17, 38, 39, 40, 41);
extern uint8_t BigFont[];
#define PARAMS1_NUMBER 8
#define PARAMS2_NUMBER 3
#define PARAMS3_NUMBER 14
byte param1[PARAMS1_NUMBER]={0,12,0,0,20,1,5,10};
double param2[PARAMS2_NUMBER]={0,22.5,34.9};
double param3[PARAMS3_NUMBER]={0,36.6,0,0,0,0,0,0,0,0,0,0,12.4,0};
File MyFile;
myGLCD.InitLCD();
myGLCD.clrScr();
myGLCD.setFont(BigFont);
while (!Serial);
if (!SD.begin(53)) {
Serial.println("initialization failed!");
return;
SaveConfig();
LoadConfig();
void writeFloat2File(File File2Write, float Value) {
byte j;
byte Data[9];
float div=1000;
float tmp;
Data[8]=0;
if (Value<0) {
Data[8]=1;
Value*=-1.0;
for (j=0;j<4;j++) {
tmp=Value/div;
Data[j]=0;
if (tmp>1) {
Data[j]=(byte)(tmp);
Value-=(int)tmp*div;
div/=10;
Value*=10000;
div=1000;
for (j=4;j<8;j++) {
tmp=Value/div;
Data[j]=0;
if (tmp>1) {
div/=10;
File2Write.write(Data,9);
float readFloat4mFile(File File2Read) {
byte j;
byte tmp;
float div=1000.0;
float Ret=0;
for (j=0;j<8;j++) {
tmp=File2Read.read();
Ret+=tmp*div;
div/=10;
if (tmp==1) Ret*=-1;
return Ret;
void SaveConfig() {
// int tmp=1;
byte j;
if (SD.exists("param1.ini")) {
SD.remove("param1.ini");
MyFile = SD.open("param1.ini", FILE_WRITE);
if (MyFile) {
for (j=0;j<8;j++) {
writeFloat2File(MyFile, param1[j]);
MyFile.close();
if (SD.exists("param2.ini")) {
SD.remove("param2.ini");
MyFile = SD.open("param2.ini", FILE_WRITE);
if (MyFile) {
for (j=0;j<3;j++) {
writeFloat2File(MyFile, param2[j]);
MyFile.close();
if (SD.exists("param3.ini")) {
SD.remove("param3.ini");
MyFile = SD.open("param3.ini", FILE_WRITE);
if (MyFile) {
for (j=0;j<14;j++) {
writeFloat2File(MyFile, param3[j]);
MyFile.close();
void LoadConfig() {
byte j;
MyFile = SD.open("param1.ini", FILE_READ);
for (j=0;j<8;j++) {
param1[j]=readFloat4mFile(MyFile);
Serial.print(param1[j]);
Serial.print("\t");
myGLCD.print(String(param1[j]), LEFT, 0+(j*20));
MyFile.close();
MyFile = SD.open("param2.ini", FILE_READ);
for (j=0;j<3;j++) {
param2[j]=readFloat4mFile(MyFile);
Serial.print(param2[j]);
Serial.print("\t");
myGLCD.print(String(param2[j]), CENTER, 0+(j*20));
MyFile.close();
MyFile = SD.open("param3.ini", FILE_READ);
param3[j]=readFloat4mFile(MyFile);
Serial.print(param3[j]);
Serial.print("\t");
myGLCD.print(String(param3[j]), RIGHT, 0+(j*20));
MyFile.close();
Thank you in advance!
