SD seems too slow for SMTP
I have used SMTP before using client.print (and client.println) but I am now trying to move as much text as I can from RAM to SD (and so I need the <SD.h> library). It does not work and I am thinking it may be because the SMTP server “dies of boredom” as it waits for my Arduino to read from the SD card and write it to the client (server?).
In the code below, I have included what I am trying (it will be uncommented if you copy+paste the code) and what already works (which will be commented when you copy+paste the code, but you can uncomment and comment the other section relatively easily). The text file I have on the SD in the code (commented).
If anyone can think of a workaround, that would be great.
#include <SPI.h>
#include <SD.h>
#include <Ethernet.h>
//-v--- Ethernet -----------
byte MyMac[] = {0xFE, 0xED, 0xBE, 0xEF, 0xFE, 0xED}; // <- The physical address of the machine's network card. Should be unique (no two network cards have the same MAC address)
byte MyIp[] = {1, 1, 1, 1}; // <- This is the not the real IP address, but for the real address I have verified that the static IP works for sending mail
byte Dns[] = {1, 1, 1, 1}; // <- Not the real DNS but I got it once through Serial.println(Ethernet.dnsServerIP()); and I know that it works
byte Gateway[] = {1, 1, 1, 1}; //<- Not real
byte Subnet[] = {1, 1, 1, 1}; //<- Not Real
EthernetClient client ;
//-^--- Ethernet -----------
//-v-- Smtp --------
char ServerChar[] = "blahblah";
//-^-- Smtp --------
//-v--- SD ------
File theFile; String line;
//-^--- SD ------
  Ethernet.begin(MyMac, MyIp, Dns, Gateway, Subnet);
  SD.begin(4);
  bool test = TrySend();
bool TrySend(){
  //*-v---- What I am trying ---
  bool SuccessOrNot;
  if(client.connect(ServerChar, 25)){
    SuccessOrNot = true;
    theFile = SD.open("Smtp.txt");   //Smtp.txt is listed toward the bottom of the code
    if(theFile){
      while(theFile.available()){
        client.write( theFile.read() );
      theFile.close();
  else{ SuccessOrNot = false; }
  return SuccessOrNot;
  //-^---- What I am trying --- */
  /*-v-- The following works if used in place of [What I am trying] ---
  bool SuccessOrNot;
    client.println("EHLO ktlan");
    client.println("AUTH LOGIN");
    //-v- Most SMTP servers require verification in the form of base64-encoded username and base64-encoded password. However, since your IP must be whitelisted by the SMTP server, you don't need authentication
    //client.println("ThisIsInBase64"); // Encoded version of 'sender@blah.blah'
    //client.println("ThisIsInBase64"); // Encoded version of the password
    client.println("MAIL FROM:<sender@blah.blah>");
    client.println("RCPT TO:<receiver@blah.blah>");
    client.println("DATA");
    client.println("to:receiver@blah.blah");
    client.println("from:sender@blah.blah");
    client.print("SUBJECT: TRIGGER");
    client.println();
    client.println("The temperature Monitor Triggered.");
    client.println(".");
    client.println("QUIT");
  //-^-- The following works if used in place of [What I am trying] ---*/
/*-v--- Smtp.txt -------
EHLO ktlan
AUTH LOGIN
DATA
SUBJECT: TRIGGER
QUIT
//-^--- Smtp.txt -------*/
// NO NEED for authentication. For many Smtp servers you need:
// My IP must be whitelisted by the SMTP server, and since it is, I don't need authentication
No, it’s the other way around. You’re sending the content to fast, without waiting for the server’s response. SMTP is a protocol. Usually the client is interested in what the server responds, it may be an error message. If you just send a playback of an earlier session the server probably doesn’t like that.
