SD to array
How do i place data from the SD card into an array?
I have searched for some examples but i just cant get the hang of it.
the format on the SD card looks like this:
321654987
456989787
546565456
56565489
The numbers represents ID's and this list can be extented when more ID's are added
I also want to compare an incomming ID with the ID's in the array. If the incomming ID Is equal to a id in the array
I hope somebody can explain how to do this with an example.
Thanks!
Just like you type - one character at a time.
Seems a shame.
Numbers? Where is your code to prove that?
I found my error already it was a wrong datatype for my array I have changed the datatype to unsigned long because the data is longer then 32,767
the code for writing to the array now works like a charm
PaulS:
That is not always true. If you already know the you should be receiving/reading n bytes do a function call that reads n bytes if available.
