i keep getting this erorr on in stalling itno\libraries\ADCTouch: loading library.properties: Error reading file: Error parsing data at line 0: Invalid line format, should be 'key=value'
Error compiling for board ESPino (ESP-12 Module).
option enabled in File -> Preferences.
the program // Using the WebDAV server with Rigidbot 3D printer.
// Printer controller is a variation of Rambo running Marlin firmware
#include "serial.h"
#include "parser.h"
#include "config.h"
#include "network.h"
#include "gcode.h"
#include "sdControl.h"
// LED is connected to GPIO2 on this board
#define INIT_LED {pinMode(2, OUTPUT);}
#define LED_ON {digitalWrite(2, LOW);}
#define LED_OFF {digitalWrite(2, HIGH);}
SERIAL_INIT(115200);
INIT_LED;
blink();
sdcontrol.setup();
// ----- WIFI -------
if(config.load() == 1) { // Connected before
if(!network.start()) {
SERIAL_ECHOLN("Connect fail, please check your INI file or set the wifi config and connect again");
SERIAL_ECHOLN("- M50: Set the wifi ssid , 'M50 ssid-name'");
SERIAL_ECHOLN("- M51: Set the wifi password , 'M51 password'");
SERIAL_ECHOLN("- M52: Start to connect the wifi");
SERIAL_ECHOLN("- M53: Check the connection status");
else {
SERIAL_ECHOLN("Welcome to FYSETC: www.fysetc.com");
SERIAL_ECHOLN("Please set the wifi config first");
// handle the request
network.handle();
// Handle gcode
gcode.Handle();
// blink
statusBlink();
void blink() {
LED_ON;
delay(100);
LED_OFF;
delay(400);
void errorBlink() {
for(int i = 0; i < 100; i++) {
LED_ON;
delay(50);
LED_OFF;
delay(50);
void statusBlink() {
static unsigned long time = 0;
if(millis() > time + 1000 ) {
if(network.isConnecting()) {
LED_OFF;
else if(network.isConnected()) {
LED_ON;
delay(50);
LED_OFF;
else {
LED_ON;
time = millis();
// SPI bus not ready
//if(millis() < spiBlockoutTime)
// blink();
