SD write after I put SD in
Hey guys, this is my first time using the SD card. I have the example code in Arduino IDE itself from the SD library. I tried that so I can see what the options are. But it's not going the way I want it to.
I want to be able to put the sd card in whenever I want. At the moment I have to put the SD card in before I turn the Arduino on.
this is what I have to try out the SD card module. (the module I have is this)
code:
  SD card read/write
  This example shows how to read and write data to and from an SD card file
  The circuit:
   SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
  created   Nov 2010
  by David A. Mellis
  modified 9 Apr 2012
  by Tom Igoe
  This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
int butt = 5;
int buttstate;
int timers;
  pinMode(butt, INPUT);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      Serial.write(myFile.read());
    Serial.print("Writing to test.txt...");
 buttstate = digitalRead(butt);
 timers= millis();
  // nothing happens after setup
    if (myFile) {
    myFile.println(timers);
    // close the file:
  if (buttstate == HIGH)
    myFile.close();
SD/SD.cpp at master · arduino-libraries/SD · GitHub
//call this when a card is removed. It will allow you to insert and initialise a new card.
void SDClass::end() {
root.close();
Looks like with a bit of code your want is possible.
Does this use another library or is this the same the Arduino already has?
Where can I find the content of "void SDClass"?
Did you do an internet search using the words "arduino sd library", which should allow You to look at the library's code?
